center console
Old Oct 2, 2007 | 07:40 PM
Rhoop24's Avatar
Default center console
How many of you guys have taken the center console out without removing the seats. The only guide I found involves removing the seats not really on my to do list. I bought a 02 console and am having trouble getting the old out. Can the upper section come off the console? Or should I just rip it out?
Old Oct 2, 2007 | 07:45 PM
InsaneAuto86's Avatar
It can be removed easily w/o removing the seats or anything else. Just turn it to the side and use some force.
Old Oct 2, 2007 | 07:52 PM
AR15 guy's Avatar
Off topic but grab some pics when you get it done. I think I am going to get a 98+ console soon.
Old Oct 2, 2007 | 08:15 PM
1slowZinthe513's Avatar
just take out the seats... its only four bolts each.. it will take you maybe ten minutes
Old Oct 2, 2007 | 08:30 PM
ThoR294's Avatar
uh... ive removed the center console numerous times without removing the seats...
Old Oct 3, 2007 | 01:44 AM
borninatransam's Avatar
yeah cant say ive ever removed the seats to take out the console. that would be like taking the heads off to change the oil.
Old Oct 3, 2007 | 06:52 AM
SnakeOiler's Avatar
You have removed all four bolts? And set the e-brake handle straight up?
Old Oct 3, 2007 | 08:58 AM
1SlowFormula's Avatar
Yes the top seperates from the main peice and there are 2 bolts under there, normally one in the center and one under the dash. You should have 4 10mm bolts holding the console on those 2 under the top section plus 2 in the storage compartment of the console...
Old Oct 3, 2007 | 09:05 AM
ThoR294's Avatar
I put my parking brake up all the way. removed the 2 bolts in the center console storage thing. then i removed the 1 bolt behind the shifter, and it came out. oh yeah, and I unplugged the cigarette lighter.
Old Oct 3, 2007 | 10:10 AM
dhdenney's Avatar
Works for me too! Never ever crossed my mind to remove the seats.
Old Oct 3, 2007 | 10:23 AM
ThoR294's Avatar
There may be bolts way up front on the center console, but every fbody ive seen they are broken. lol
Old Oct 3, 2007 | 04:04 PM
Rhoop24's Avatar
My e-brake doesn't go like straight up. So it's kinda hard working around it cause that top piece hits the dash.
Old Oct 3, 2007 | 06:53 PM
BizZzatch350's Avatar
Moderator
I have never taken the seats out to do a center console, makes no sense and just adds work. You can get it in it easy with the seats in, the bolts are all inside the console it self.
Old Oct 3, 2007 | 07:22 PM
AR15 guy's Avatar
Remove the e brake handle part. It is held in by one bolt on the side.
Old Oct 3, 2007 | 10:25 PM
Biggin'89's Avatar
or use a screwdriver to pop the "ratchet arm" off of the sprocket so it doesn't engage the brakes.
Old Oct 4, 2007 | 11:34 AM
H82GOSLW's Avatar
You can do it without taking the seats out. But if you must, as someone else said there are only 4 bolts holding the seats down. It should take you 5 minutes to get them out.
Old Oct 10, 2007 | 08:37 PM
Rhoop24's Avatar
Got it in there finally took out the pass. seat my E-brake just doesn't stand up high enough. Note this is before I got it all screwed down and the Park-1st set in there correctly.
