A/C delete problem
Old Oct 7, 2007 | 12:35 PM
yamaryder6's Avatar
does anyone know if thereis even an ac delete pulley made for the vette. ac is in the opposite side than camaro and firebird and i cant find an ac delete anywhere! thanks
Old Oct 7, 2007 | 12:37 PM
the_merv's Avatar
Veteran: Air Force
Maybe the same one..the Compressors look identical..
Old Oct 7, 2007 | 12:38 PM
the_merv's Avatar
Veteran: Air Force
Originally Posted by Hark_Z
Helps to have a visual:
I don't like how close the Tranny Lines are to that Belt...just my opinion..
Old Oct 7, 2007 | 01:13 PM
Scrapin'4.8's Avatar
Ok..it may just be me, i don't even know if it's possible to do or not, but is the belt tensioner on upside down???? I haven't looked at mine in a lil' but for some reason i think his might be installed wrong. Hell the more i look at it i think i'm almost positive it is. The first picture the pulley should be up between the other two pulleys instead of below it since there's no pressure on it pushing it down, the 2nd picture it should be up between them even more than that, which is why he's got so much slack. And now i read he had problems getting the belt on so i'm assuming he didn't use the belt tensioner to give himself some slack to get the belt over one of the other pulleys. But i could be wrong, i work on an LT1 caprice, something on there may be different.
Old Oct 7, 2007 | 01:32 PM
DADDY&GIRL93TA's Avatar
So it was the 61.5 belt that worked?
Old Oct 7, 2007 | 03:31 PM
Hark_Z's Avatar
sorry guys Im short on time now but it was the 61.5 that worked. I dont think the belt tensioner is upside down..? That could make sense because the belt barely rests on the tensioner now..but that would mean I need a diff belt again. Hopefully stock 63.5.
Old Oct 7, 2007 | 03:32 PM
Hark_Z's Avatar
Also I did realize the tranny lines were close Im going to keep an eye on that when I get the tranny back in, thanks.
Old Oct 7, 2007 | 03:43 PM
It should work with ur stock belt if it is in fact upside down.
Old Oct 7, 2007 | 04:47 PM
the_merv's Avatar
Veteran: Air Force
He's right..it is upside down..I'm suprised I didn't notice that..good catch.
No it won't..look at the pic and you will see..
Old Oct 7, 2007 | 06:20 PM
dhdenney's Avatar
Hmm, I didn't think it would go on upside down! But to reiterate, I had to use the shorter belt cuz the pulley (like in the pic) is almost 1/2 the size of the compressor pulley.
Old Oct 7, 2007 | 10:41 PM
Hark_Z's Avatar
No wonder I had so much trouble with finding the right belt before..Ok I put the tensioner on the right way and once I loosened it the stock belt fit like a glove. Thanks for pointing that out guys I would have been screwed.
Old Oct 7, 2007 | 10:48 PM
  #32
TwoFast4Lv's Avatar
Thnaks Guys! I never looked at mine much when I put it on a few monthes ago.
Turns out I had to shim it over 3/16th of an inch! Now it fitts great and hitts 7,200 with out tossing it!
Now to go revue the vendor that I got it from.
Old Oct 8, 2007 | 04:22 PM
  #33
Good deal!! i knew something was off with it!! Had me scared a lil' too though cause i just ordered the same pulley off ebay and wasn't wanting to change my belt!!
