Stall Converter
Old Oct 8, 2007 | 06:39 PM
curtis95ta's Avatar
Default Stall Converter
I'm basically new to stalls and what not so i have a little clue on what to get (thinking around 2400-3000 stall) but im sure there are others here who would know more on the subject. So heres my post.
What would be the best for a daily driver, i will be driving the car daily and don't want the constant jerking i hear some get from a higher stall...BUT i will be taking it to the track frequently....
So my question is...i want it to perform as best as possible and yet be somewhat nice to drive on the street for a cruiser.
The Car is a 95 pontiac trans am.
LT1
4L60-E
stage 1 (or 2) shift kit undecided right now.
slp headers
3inch magna flow cat back
lt4 knock module
the sooner the response the better
Thanks In advance
Curtis
Old Oct 8, 2007 | 06:54 PM
C_Rules's Avatar
go with a 3k and you'll be fine. you won't notice anything really different until you step on it. car will seem the same around town except you wont get into the powerband until a little later. i have a 3K in mine and i'd go even bigger without even giving it a second thought.
mthegodfather's Avatar
2800 to 3000 would be perfect for you.
Old Oct 8, 2007 | 07:10 PM
96capricemgr's Avatar
I agree on the 2800-3000 but would like to add go with someone like Edge, Yank or Vigilante 9.5". Consider gears in the not too distant future, 3.73s are nice with an auto and make a converter drive even nicer.
Old Oct 8, 2007 | 07:18 PM
curtis95ta's Avatar
3.73s will come shortly...but right now its transmission work that needs to be done...
thanks for the quick input guys, much appreciated....i think i will do the 3000. I was a little hesitant at first but if its just less power down low won't be much of a problem for me....
Old Oct 8, 2007 | 09:27 PM
bigdan1's Avatar
like 96caprice mgr said go with a small O.Dia. stall converter they drive much crisper in normal driving then the modified 12" stall ....( more expensive but much better)
Dan
Old Oct 8, 2007 | 10:52 PM
nomoneyz's Avatar
I have 3200 stall in my car with 2.73s. Its a little loose in town with the gears but man does she move when you hit the pedal. Getting a lockup converter is a plus. My gas milage hasn't even changed with this one.
Old Oct 9, 2007 | 10:19 AM
3pnt4maro's Avatar
Yeah i agree go with a good name brand...I went with EDGE and havent looked back...Im just glad i didnt cheap out on this mod....I need to get some gears now
Old Oct 9, 2007 | 12:26 PM
CamaroRacing12's Avatar
dont be a girl.... i DD my car in the summer and this winter a 3600 vig is going in her!
Old Oct 9, 2007 | 12:42 PM
cpt_bimes's Avatar
I had a Yank SS 3600 in mine and ran the times in the sig.
Around town you could drive and the tranny would shift and keep the RPM's around 2K no prob.
Old Oct 10, 2007 | 07:25 AM
mliers's Avatar
I've got a 3200 yank and it drives just great around town.
Old Oct 10, 2007 | 09:41 AM
mliers,
what kind of 1/4 mile times r u getting... sounds like a sweet and clean setup u got there
Old Oct 10, 2007 | 10:01 AM
mliers's Avatar
best time the car has got with a 150 shot is 11.01...12.3 without the nitrous
Old Oct 10, 2007 | 11:07 AM
she prolly def has 11's in here N/A and 10's with the N20....
Old Oct 11, 2007 | 07:55 AM
97blkz's Avatar
Get at least a 3200 stall to make it worth the purchase. My car has one and it's street friendly and does OK at the track!
Old Oct 11, 2007 | 08:09 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Just one thing to mention,
with 94/95 ODB1 PCM's if the Stall wall fix hasnt been put into the pcm, then the trans will freak out and put it into 3rd. My mild 2500/2800 stall used to do that.
As for stall range, something in the 3000-3500 is perfect, my old LT1 dyno graph shows the increase of 50 ft-lbs of tq from 2100-3100 rpms.
