LS1 Swap
Old Oct 14, 2007 | 01:41 PM
  #41
SmokedOutZ28's Avatar
Originally Posted by Cheap Guy
WOW, that's more than I thought it would be, probably because I didn't think you'd need a new tranny and assorted parts. That's "only" three grand less than the Lingenfelter LT1 I was "somewhat" considering.
I with you on that... I was thinking about swapping as well then i decided that i might as well continue with the stroker project.
Old Oct 14, 2007 | 03:18 PM
  #42
Cammed95Z28's Avatar
Originally Posted by Akira_X
eh I was gonna get an engine off of ebay, they are not that expensive there. Also I was hoping to use the t-56 from my lt1 and just change the bellhousing and buy the LS1 drive shaft.
That would knock a bit off that list if I could...
Its just as expensive to modify the LT1 trans. I have checked and talked to alot of guys who have done the swap. From my research, its better to buy the LS1 trans. The LS1 bellhousing won't bolt up to the LT1 T56, also you have to change the imput shaft, and all the hydraulics(slave cylinder, clutch, flywheel, etc.). Thats why I found a used LS1 T56 for 1600 so i'm pouncin' on it. Also the LS1 motor i got was out of a 01 vette and i know the owner so its totally worth the 2K for me.
Old Oct 14, 2007 | 03:42 PM
  #43
Akira_X's Avatar
Yea I did some research for a bit yea it's probably easier to buy a new one.
ah cool well it's always good to buy from someone you know, but what about the tranny? why so expensive? same story?
Old Oct 14, 2007 | 08:16 PM
  #44
A list price from a dealership for a new LS1 T56 is 4500 dollars!!!! I called jason cromer and he could get me a brand new one at 3200, so finding one with 55K on it for 1600 is a pretty good deal. Also if the tranny needs to be rebuilt its only like 400 bucks or so, so i'm not so worried about the miles on the tranny.
Old Oct 15, 2007 | 12:21 AM
  #45
Akira_X's Avatar
that's interesting, I've been seeing trannys for real cheap on ebay.
Old Oct 15, 2007 | 03:05 PM
  #46
Yeah i think i'm done with Ebay, ever since I bought a pair of used AFR's for 1800 bucks. They never showed up and the poor excuse for a human being that sold them to me was never found. The police in Florida "did all they could to find him" but never did. No me gusta EBAY!!!!!!
Old Oct 15, 2007 | 07:50 PM
  #47
Cheap Guy's Avatar
Default Crate drop in for LT1's
Maybe I'm getting a little off topic here, but I find it incredible that GM doesn't have a straight drop in crate motor for 93-97 LT1's. I understand that the LT1 has been "replaced" by the LS1, but you would think GM would still make it easier for the older F-Body crowd.
Old Oct 15, 2007 | 08:03 PM
  #48
daniel6718's Avatar
dang...ls1 motor tranny t56 and cpu wire harness for 4875?
omg i just sold ls1 and t56 with pcm and harness for 3500
when i didnt have a rack i got one from a junkyard for 80...
k member for 40 bux...
fuel lines and everything needed for my fuel system was 20 bux
Old Oct 15, 2007 | 09:28 PM
  #49
Like i said, everything i have down is an estimate. we will see how it all pans out in the long run.
