What brand stall should I get?
3000-3500 is more then enough for the street/strip.
FYI if its a 94/95 trans you need the stall wall fix, 93/96/97 dont have that issue.
Like I said the difference between Edge and then Vig and Yank is Edge has a stamped cover instead of an overkill billet one, that accounts for the $200 difference in price. You get down into the $400 range of Fuddle, Midwest, TCI then you are getting cheap parts in every sense of the word.
Several guys on the b-body boards have gone back and forth between Edge and Yank and consensus seems to be Yank drives a little better and Edge launches harder, nobody said the Edge drove badly though. A few guys who have had Vig and Edge like the Edge better.
Price is no guarantee of quality either, I had a $7-800 billet Level 10 2600 stall that drove worse than the 3400 Edge and ran HOT, not to mention the hub being .1" runout, not a typo a tenth of an inch.
Ask the companies you talk to what future rework costs, some have a high flat rate others charge for actual repair necessary. If you put a stall in front of a stock tranny eventually the tranny is going to wear out(not the fault of the stall) and the converter will need to be gone through. Choose carefully and the choice can save you money for years to come.
--Alan
The fastest bolton b-body is running I think a 3600 Yank with some special internals, that guy is amazing at wringing out a car though 12.3 NA 11.3 on a 150 shot, stock heads and cam, is not a street car though 4.88s out back and such, not cut up but signifigantly bolted OFF.
Converter choice is a big decision and you will always hear both sides on certain companies. IMO as stated, you can't go wrong with Yank, Vig, Edge, ATI.
Any COMPETENT tuner can easily deal with it in the programming, even some incompetent ones can if they remember. Some of the high volume guys make A LOT of mistakes, things like forgetting to fix this and such, so if you have the issue it is a tuning thing.
Thanks, I did not know that. I learn something everyday.
