Safe rev limit for a superchargered lt1?
Old Oct 15, 2007 | 01:25 AM
onefastbird95's Avatar
Default Safe rev limit for a superchargered lt1?
What is the rev limit for an lt1? I know the tach goes to about 7000, but I am looking for a reasonable and safe rev limit to set my msd ignition at. Does the rev limit differ if a supercharger is on the car or would it be the same for stock as well?
Old Oct 15, 2007 | 02:23 AM
wickedbusa's Avatar
I'm running a Vortech T-Trim running at 16 lbs. My rev limit is set to 6500. I have an MSD Digital 7 as my ignition box.
Old Oct 15, 2007 | 09:45 AM
kinglt-1's Avatar
dont bother taking it up over 6000 if your motor is stock, or something is gonna give!!!
Old Oct 15, 2007 | 10:19 AM
jasonp31's Avatar
What valvetrain are you running? The supercharger doesn't change where you should shift just because you are making power above the stock RPM limit. The valvetrain is the big concern as far as I know. I don't know about what the conn rods will handle, RPM wise. I know for a fact that the weak 85lb springs from the factory are not going to handle a lot of RPM, especially with the extra power you're now pushing with the s/c.
Old Oct 15, 2007 | 02:47 PM
my motor is pretty much all stock with an vortech s-trim on it... so I figure not go over 6000... I have my msd set at around 5600 or 5800 right now to lean toward the safe side... if I take it to the track I would bump it up to 6000 probably. thanks for the help guys I just wanted to see what others were doing!
Old Oct 17, 2007 | 09:48 AM
Boodyrider's Avatar
You need to set shift points based on the power curve... but if you have stock heads, you are not making any power to speak of above 5600 anyway. The heads and especially stock intake won't allow for much flow above that.
Old Oct 17, 2007 | 09:49 AM
Boodyrider's Avatar
And the stock rods don't like high revs, certainly not without ARP bolts.
Old Oct 17, 2007 | 10:28 AM
RealQuick's Avatar
Thats good right there.
Old Oct 17, 2007 | 01:03 PM
95N20FORMULA's Avatar
im bolt ons only and rev to 6000 with 170k miles so i say u should be good with 6k rpm shifts
Old Oct 17, 2007 | 03:47 PM
Pampered-Z's Avatar
It's also important to know which SC your using and where it's RPM limit is. I'm running a P600B with 15lb pullies so 6200 is the max I can spin the motor or I'll overspin the SC.
Old Oct 17, 2007 | 07:23 PM
Yes very good points guys! Thanks again for the feedback!!
