Cooling issues (urgent)
Remove the thermostat and see what happens, won't be the first time a new thermo. was bad!
Check that nothing got up under the front of the car and is blocking the rad. such as a plastic bag or something, then check the hoses, an old hose going bad could colaps when hot causing a restriction. Run the car with the cap off and make sure the coolant is flowing, this will also let you check the rad. cap is good.
I doubt anything is wrong... I thought the same thing until i SEARCHED and read into it. I jumped the relay and it never got hot again.
