Need a good book for rebuilding LT1's..
How to Rebuild Small-Block Chevy LT-1/LT-4 Engines by Mike Mavrigian. It's published by HPBooks. I'm in the process of reading it now and it seems to have pretty much everything.
I wasnt to happy with it. It had alot of good stuff for a stock build. But that was not the direction i wanted to go.
There needs to be a "How to Rebuild a High Performance Small-Block Chevy LT-1/LT-4 Engines"
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
shortblock wise they are basically the same so you are trying to overcomplicate things which will not be a good thing come time to turn wrenches.
The LTx motors are a slight tweak of the old gen 1 stuff. The cooling circuit is different but the injection/ignition is the real big difference.
The heads are a big improvement over gen 1 production stuff but GM took what they learned with the iron LT1 heads and used it in standard coolant flow on the truck Vortec motors starting in 96 which are a gen 1 motor.
