Rerouting the belt
Old Oct 20, 2007 | 03:07 AM
rocket22's Avatar
Default Rerouting the belt
Anyway to run the belt so it's not turning the a/c, I need to run a test to elimate acouple problems I might have.
Old Oct 20, 2007 | 04:13 AM
Formula350's Avatar
If I remember right, there isn't since it then messes up the direction the belt is. I might be wrong.
Old Oct 20, 2007 | 09:58 AM
CRAZZ28's Avatar
If you are just taking it for a quick drive you can run it without the belt.
Old Oct 20, 2007 | 11:37 AM
Captainofiron's Avatar
I dont know for sure, but the power steering pumps and pumps in general are usually directional
Old Oct 20, 2007 | 03:27 PM
ThoR294's Avatar
you cant. just take the belt off
Old Oct 20, 2007 | 06:32 PM
sdm1234's Avatar
i don't think there's a way to re-route the belt. good luck with the problem.
Old Oct 20, 2007 | 07:26 PM
Razor_Blade's Avatar
Sure you can. Don't forget the waterpump is not driven by the belt. You could drive without a belt until the battery goes dead. That would be quite some time if the lights aren't on.
Old Oct 20, 2007 | 07:42 PM
fergymoto's Avatar
^He meant you can't re-route it I'm pretty sure.
Old Oct 20, 2007 | 08:02 PM
Formula350's Avatar
Yea, he did. I typed a whole message saying the same thing, till I re-read and saw what he intended.
Old Oct 24, 2007 | 02:13 AM
rocket22's Avatar
Thanks guys, I haven't had time to mess with it, but I think the A/c clutch bearing is shot, but I can't tell between the A/c or the Alt so wanted to turn the Alt but not the A/c, I'm pretty sure it's the A/c bearing, because with the air on it quites down alot.
Old Oct 24, 2007 | 03:52 AM
Formula350's Avatar
I don't mean to sound like an *** (I'm going to), but you can't tell the difference between your Alternator and your AC Compressor? o_0
Old Oct 24, 2007 | 10:28 AM
1994Z28Lt1's Avatar
sounds like you've already answered your own question
if the a/c idler pulley bearing was going out it would make noise until you turned the air on engaging the compressor in which case the idler would be locked to the input shaft of the a/c compressor which would no longer spin that particular bearing
Old Oct 24, 2007 | 02:29 PM
rocket22's Avatar
Well, between the cam, and the noise, from the top it sounds like it could be either or, But I was watching the A/C compressor, and with the A/C off the pulleys is wondering alot, so I'm pretty sure it's the A/C.
Old Oct 24, 2007 | 03:16 PM
roadhog_113's Avatar
why don't you get an a/c delete pulley?
Old Oct 26, 2007 | 12:29 PM
rocket22's Avatar
Because with the hot summers here, and it just being a street only car, I want the A/C still, thought abought a pulley has a temp fix so I drive it till the winter sets in.
Anyway thanks guy.
