White Trash needs your help
Old Oct 21, 2007 | 06:17 PM
1BAD01TA's Avatar
Default White Trash needs your help
Ok so everythings going good on my 93 ta then I decide to tackle the brake lights. This is where it gets interesting. If you hit the brakes all three light up the left and right are very dim, Then you turn on the lights and all the rear lights go out or stay very dim VERY DIM. So I figured ground bulbs switch somthing simple.....none I rewired the rear ground cecked and replaced all the bulbs changed the switch.....nothin same issue.
A couple of other things when the key isnt in the ignition and you hit the brakes the key chime sounds.....It dosnt do it with the key on but ive never had another car that did this.
and withe the brake lights on but dim the tag light is on but very dim....thats with the lights off?
I checked voltage at the bulbs and its a crap shoot sometimes 11.4 and then 3.8.
Im really at my wits end on this one so if anyone can help PLEASE
1BAD01TA's Avatar
please
Old Oct 21, 2007 | 07:42 PM
Formula350's Avatar
You might want to post this in the Stereo and Electronics section :\
Old Oct 21, 2007 | 07:54 PM
1BAD01TA's Avatar
ive tryed
Old Oct 21, 2007 | 10:15 PM
dhdenney's Avatar
Sounds like maybe the sockets are corroded and need replacing. Seems like I had a similar problem a number of years ago and this fixed it. You can get Calterm replacements very cheap and just splice them into your previous sockets' wiring.
Old Oct 21, 2007 | 10:49 PM
Formula350's Avatar
Not that it really matters with wiring, but if you're 01, you're in the wrong part of the forum anyways. You should be in the LS1 section, not the LT1.
Old Oct 21, 2007 | 10:51 PM
infinitebird's Avatar
you obviously didn't read the post
and lol @ thread title
Old Oct 21, 2007 | 10:56 PM
LT1MAN's Avatar
i had a similar issue in my last camaro. turned out it was a socket that was full of corrosion that was similar to peanut butter almost. a little bit thinner and more grainy.
Old Oct 21, 2007 | 11:01 PM
Formula350's Avatar
hah I did, and I completely forgot
I believe that is just the electrical compound they put in factory. And the age is what made it chunky. It may have started out a different color and oxidation made it that peanut butter color. I know exactly what you're talking about though.
Old Oct 22, 2007 | 09:24 AM
dhdenney's Avatar
Yeah I think it's some sort of dielectric compound. It's kinda nasty if you get it on your hands. LOL.
Old Oct 22, 2007 | 09:33 AM
moserman's Avatar
yeah i had fun getting that all over me hah. i had a similar issue in my 96 s-10 and it was because my alternator wasnt pushing out enough volts with a pully system i had on it. i would reccomend checking to see if your alternator is running 100%? just throwin out some ideas for ya.
Old Oct 22, 2007 | 10:28 AM
Revelation Z28's Avatar
lol all you do is post ***** and not even read the threads.
Old Oct 22, 2007 | 11:33 AM
1BAD01TA's Avatar
cant we all just get along
Old Oct 22, 2007 | 11:34 AM
dhdenney's Avatar
Seriously, buy one Calterm socket for like $4 and see if that fixes it. It sounds just like my deal a few years ago.
Old Oct 22, 2007 | 11:47 AM
Platinum WS6's Avatar
I had the same problem with my 94 Z28, turned out that there was some grease inside the socket and was causing the connection to mess up. I cleaned it out really good and that fixed the problem. Hope this helps.
Old Oct 22, 2007 | 02:02 PM
1BAD01TA's Avatar
that much of a issue caused by a socket, Im gonna try after work.
Old Oct 22, 2007 | 02:27 PM
edcmat-l1's Avatar
Did you check the main connector to the rear wiring harness? Its on the drivers side in the rear.
Old Oct 22, 2007 | 02:33 PM
dhdenney's Avatar
Yeah it was something my dad suggested and I didn't see how it would fix it either but it did.
Old Oct 28, 2007 | 07:51 PM
1BAD01TA's Avatar
guess what a I replaced 4 of the sockets and it fixed it.
Old Oct 28, 2007 | 10:45 PM
dhdenney's Avatar
I thought that might do it.
