belt to use with asp pulley? i searched
i have a ASP Crank Pulley and it squeaks every once in a while and when it rains. figured i would try to change the belt first. anyone have a part number that is using a asp underdrive pulley? i would hate to pull it off at a part store
thanks
-travis
thanks
-travis
i'm not sure, myself. but i'm sure there are links out there on the web that will tell what size to use. are the ASP crank pulleys the same size as the March pulleys, for example? if so, I know most links to the march pulleys list a belt size to use. hope this helps!
