is my vacuum to low?
Old Oct 25, 2007 | 11:52 PM
Chris18927's Avatar
Default is my vacuum to low?
ok i have a cc306 w/ 1.6 rr's with stock heads and intake manifold and when i put the car in drive and let it idle i only have 6 inches of mercury of vacuum in the intake manifold. That seems low to me, should it be that low?
Old Oct 26, 2007 | 01:00 AM
Ralls's Avatar
Too low. Even with a cam, your looking at around 15-20 inHg
Old Oct 26, 2007 | 08:03 AM
kinglt-1's Avatar
My car pulls 16inches vacum when its cold, 18-19 warm. Im gonna say you have a vacum leak or your piston rings are toast. Mods in sig!!!
Old Oct 26, 2007 | 02:30 PM
Chris18927's Avatar
could that explain low/mid rpm stumbling/missing/sputtering when hot?
Old Oct 26, 2007 | 02:43 PM
moserman's Avatar
might want to look into hydraboost after you get that vacuum leak checked out. it might be an intake leak if you cant find any hoses or anything like that. hopefully its not the piston rings!!!!
Old Oct 26, 2007 | 02:59 PM
Ralls's Avatar
Is the vacuum gauge steady or bounce around? Could have an intake manifold leak. Spray some choke cleaner or whatever you have around the intake to see if there's a leak. What all is done to the motor and are you tuned for the cam?
Old Oct 26, 2007 | 03:54 PM
Chris18927's Avatar
yes im tuned for the cam, i have a madz28 tune for it and not much is done to the car except what is in my sig and new valve springs for the cam. i think i my rr's my be to tight, they always come loose so i always screw em in really tight so mybe they are to tight and the valves dont seat?
Old Oct 27, 2007 | 12:51 AM
Ralls's Avatar
You tighten them until you can't spin the push rods with your fingers. And then a 1/2 or 3/4 turn after that. Is that what you did? If you over tighten them, your looking at some damage. Use loctite if you need to.
Old Oct 27, 2007 | 01:48 AM
Chris18927's Avatar
i screwed em down a half turn to start with then each time one would come loose i would run the car and screw it down till the noise of the loose rr went away
