LTx vettes
Vette's have IRS and the M6s come with Dana 44s, which are the better, stronger, rears. 3.42s as well. They also use Mono-Leaf in the front and rear. You'll probably say "Ew leaf spring" until you find out that even the Race version Vette's KEEP the same suspension setup, it's that good.
Ride control has 3 settings. I don't remember the exact labeling, but basically it's like Cruise, Street and Race. The shocks then adjust via air to the appropriate stiffness, and it's not a gimmick you can tell the difference in ride right away, as well as handling.
The "Idiot Light" cluster is just a big black area, so that's kinda tacky. The stereo is down by the bottom where the shifter is, so that's kinda lame too. Should be up a bit higher IMO. Ride control is called RPO FX3. There are alot of different options. The build sheet will tell you everything. Its located under the console lid or under the small storage compartment cover in the back behind the seat. Getting/out of the C4 is a PITA. The other end of that is once you get in, its really like a cockpit. Theres a saying that you dont sit in a C4...you wear one. Theres some truth to it. You get better road feedback from the C4 than the C5. Most vette owners that have had both a C4 and C5 will agree on that. The C4 just 'FEELS' more like a sports car. The interior design is somehwat subjective. The radios suck in about all corvettes. Just go look at em and decide.
I really like both the F cars and the Y cars but for different reasons.
Just for comparisons sake...http://forums.corvetteforum.com/show....php?t=1853005
and
http://forums.corvetteforum.com/show....php?t=1842395
Weather striping is one of the things to look for in C4, its goes bad on most of them and its expensive to fix. Also corvette tax will get you on anything that need to be fixed or even modified(if you dont know what that is lookup how much weather striping really is for a c4). The dana 36 is good up to 400rwhp at the track. The targa top is kinda hard to get off (4 screws i believe). A C4 is alot smaller then C5s but it give you this fighter pilot feeling. If your tall i would get an auto, Im 6'4 and its really hard to use the cluch in a C4.
If you want more info check out corvette forums, im sure they can help you out better on pros, cons and what to look for.
