30# injectors too much?
This thread has now been as dumbed down as is possible.
Good Luck,
Daren
I'm not trying to disagree with you at all about what you said. I'm just saying there is still nothing wrong with a bigger injector if properly tuned.
Mike
Good Luck,
Daren
If it's a stock LT4, it will have 28lb injectors not 24 last time I checked.
They ARE NOT JETS. The computer controls the amount of time the injectors is open and when. For less fuel it is open shorter periods of time. It will drive the same as long as it is tuned well...
The bigger the injectors the harder low RPM tuning gets because sometimes it is hard to get the injectors to open and close fast enough, hence richer than ideal conditions. THOUGH 30lbs injectors wont be anywhere that point. I have 42# in a stock Lt1 with a lil boost. Runs like it did stock out of boost.
Only huge injectors are said to have that problem.
The fact that I have tons of dyno time and that I data log almost every pass, have set a stack of IHRA National Records in Stock Eliminator, and can cut low 1.3 sixty foot times in a 3200 lb N/A LT1 car means nothing.
I'll try to keep advice like this to myself in the future.
Take Care,
Daren
That doesnt mean stockers are fine and to just kill your fuel system with high PSI, but just like everything else there has to be a balance.
