Changing from Synthetic to Regular Oil-Problems?
Old Nov 8, 2007 | 06:08 PM
Black94Z28's Avatar
Default Changing from Synthetic to Regular Oil-Problems?
Well, after doing an oil change and reading that Mobil One synthetic will cause leaks in our LT1's, can i change back to regular or something else that will not cause my engine to sprout leaks everywhere? Or am i SOL?
Old Nov 8, 2007 | 08:10 PM
camaro-94-z28's Avatar
when i first talked to a mechanic when i got my car i asked if there was a way to tell if the guy was running synthetic. he said no and that it doesnt matter if u switch back. i would wait untill someone else chirps in. im not sure if a switched from syn. to dinasor oil but if i did i have no problems
Old Nov 9, 2007 | 09:05 AM
Rocky70304's Avatar
I have always been told that if you switch from petoleum based oil to synthetic there is no harm, but once you use synthetic oil you can never switch back or you will cause leaks. I do not know if this is true that is just what I have always been told.
Old Nov 9, 2007 | 09:22 AM
BlackScreaminMachine's Avatar
Internet Mechanic
You can switch with no issue.
Synthetic DOES NOT cause leaks, they find them.
Old Nov 9, 2007 | 09:36 AM
96lt1m6's Avatar
i would leave the synthetic in there,conventional oil really sucks these days!
if you have leaks its time to replace a few gaskets.
Old Nov 9, 2007 | 11:21 AM
Shaine's Avatar
You dont want to switch back the chemical composition of synth. is thiner cuts bearings differant when you switch back it will wear things out much faster as well as leaks will form
Old Nov 9, 2007 | 11:35 AM
HFLDtA's Avatar
Old Nov 10, 2007 | 11:40 AM
snksknr's Avatar
Synthetic oil is born from conventional oil. Chemists remove certian molecules from the conventional oil and that is what makes it synthetic. You can change from convetional to synthetic whenever you want without any problems. You can even mix them together. And as for your leaks they were going to occur regardless of the type of oil used.
