Found My Massive Oil Leak!!!
Old Nov 11, 2007 | 07:59 AM
Black94Z28's Avatar
Default Found My Massive Oil Leak!!!
Well, found out it wasnt a valve cover gasket leaking, installed new gaskets, cleaned all the oil off the block with brake cleaner, and took it for a test drive. Came back and the oil pan, starter, and passenger headers had oil all over them.
Got the car up on stands, pulled the y-pipe off and the starter and saw my dipstick tube was covered in oil with a trail of oil along the block next to the tube.
Once i got the bolt out and pulled the dipstick, saw where the bracket attaches to the dipstick tube, there was a hole in the tube from where the bracket had torn away from. I didnt expect all that oil to come out from the tube, but i guess so.
So...does anyone have an extra tube laying around or know where to get a factory one? AutoZone and such just have the chrome press in universal tubes, which i'm scared to use.
Old Nov 11, 2007 | 08:28 AM
SprayedLT1's Avatar
New ones are only $13 at the dealer.
Old Nov 11, 2007 | 11:19 AM
TwoFast4Lv's Avatar
What he said. I just ordered three of them I ruin mine just about every time I take it out.
Here is a install hint if you have headers. Cut all but an inch or so off the bottom ring where it goes into the block . This also help keep oil from blowing back out of the stick many times
Good luck!
Old Nov 11, 2007 | 12:04 PM
daves94formula's Avatar
Wow he just described my oil leak to a friggin t. New dipstick tube here i come!
Old Nov 11, 2007 | 12:12 PM
Blackbirdws6's Avatar
just had this same issue. Replacing mine with a Lokar unit. Install is so so but PITA to get it on a header bolt. I would get enough oil to put specs of it on the rear of the car.
-Brian
