Couple questions
Old Nov 14, 2007 | 01:22 PM
fordeater's Avatar
Default Couple questions
I am re-doing my motor again and was womdering if it is a good idea to replace the oil pump drive if I doing all this work, its getting a new cam, new GM pump and a melling driveshaft. I have heard bad stories about the drive gear getting messed up after guys put a cam in it, so is it a god idea to replace it?
Also what are a good roller lifter to use, I had comps but they seemed really noisey. Thanks alot!
Old Nov 14, 2007 | 01:46 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Replace it with a Bronze gear drive, it seems to be the most durable. You can use comp replacement, but depends on the cam size and lobes. Unless its something radical where a Morel is needed, I dont see you needing anything over stock replacement.
Old Nov 14, 2007 | 01:48 PM
fordeater's Avatar
its just a 280XFI, was thinking about just buying a GM replacement
Old Nov 14, 2007 | 01:55 PM
Internet Mechanic
Ive hear enough horror stories with a stock one stripping and spinning all the bearings becuase the oil pump uses the gear drive to turn, off the cam.
Its a 40$ peice and well worth the insurance.
A FYI when I tore down my 383 for a cam swap it had like 10k on the clock, the stock replacement that was in there was a lil worn and was not recommended to re use.
Old Nov 14, 2007 | 01:56 PM
Internet Mechanic
Cam Specs with 1.6 rockers at .050": 230/236 .576/.571 113 LSA
I used the bronze gear drive with far less cam....
Old Nov 14, 2007 | 03:05 PM
Vicious95Z28's Avatar
I THINK HE'S TALKING ABOUT THE ACTUAL SHAFT BETWEEN THE DRIVE THAT RUNS OFF OF THE CAM AND THE OIL PUMP. If so I think that it's a good idea to replace it. I used one from ARP. The gear on the oil pump drive doesn't need to be upgraded/replaced unless it's worn, atleast not for the cam that you're using.
My bad, I was confused at 1st. I still don't think you'll need to replace the gear though unless it's worn.
Old Nov 14, 2007 | 08:18 PM
fordeater's Avatar
im wanting to replace the gear, not the shaft. I have heard some stories about guys putting in the stock one with all new parts and it stripped. I used this one with the first cam swap and only had about 70,XXXon it stock including 4,XXX with the first cam. mabey it will be fine but its only like a 40.00 part from GM
Old Nov 15, 2007 | 06:16 AM
Internet Mechanic
So I was right, AWESOME!!
Anyways get the bronze one, its cheap insurance.
Old Nov 15, 2007 | 11:16 AM
fordeater's Avatar
Part #
Old Nov 16, 2007 | 09:25 PM
fordeater's Avatar
anyone got a part# on that bronze gear drive from comp
Old Nov 17, 2007 | 07:30 AM
Internet Mechanic
I wish I had it man, try cz28.com (camaroz28.com) its a common question, or PM SStrokerAce, he is the one that sold me mine. I no longer have the recipt. If I come accross it, ill post it.
