lt4 head gasket ???
Alittle more compression is good for you
Is the block stock? you need to know what the deck height is before you pick a gasket.
You want the deck height + gasket thickness to be about ~.040
Deck height is how far the pistons are below the block surface at their highest point.
If the block has the normal deck height of ~.028, then just get the thinnest gasket around, which I believe is a .026 that summit carries. Not optimal, but it will work.
