Help with o2 sensor removal...
Old Nov 18, 2007 | 07:37 PM
jasonp31's Avatar
Default Help with o2 sensor removal...
As a part of my continued restoration, I purchased some new o2 sensors this weekend. The car is a 95 formula, so it has two upstream sensors. The driver's side was a piece of cake, but the passenger side has turned into a job in itself.
What I have tried:
1. Adjustable wrench. Multiple angles, flipping the wrench, no go.
2. Unbolted the starter for more room. Helped to get more leverage, but still, no go.
3. Using a screwdriver with the above wrench, for more leverage, no go.
4. Went out and bought an o2 sensor socket. Used a breaker bar, no go.
5. Used a metal bar (somewhat flimsy, didn't help a lot, but helped apply more torque) No go.
6. Started the engine, let it run up to operating temperature. Shut the engine off, let the pipes cool down a little, since their is a lot of exhaust in the way. Didn't seem to help.
I can't get this thing to budge. It's almost like it was welded in. (it's not by the way)
Any ideas or tips?
Old Nov 18, 2007 | 09:14 PM
transamws6_97's Avatar
pb blaster it like 5x a day for a day or two itll come loose
Old Nov 18, 2007 | 10:06 PM
infinitebird's Avatar
The easiest way is to cut it off so you can fit a deep socket over it.
Old Nov 18, 2007 | 10:07 PM
iceman15's Avatar
Go to an autostore and rent an O2 socket it makes your life waaaay easier. Had the same problem with you and tried everything then i got that o2 sensor and got it off in 30 seconds. haha get one
Old Nov 18, 2007 | 11:32 PM
lookin4aTA's Avatar
Hit it with some PB Blaster and cut the wires so you can use a socket for it. Took me like 20 seconds to get it out after that.
Old Nov 19, 2007 | 08:17 AM
jasonp31's Avatar
OK, how about everyone READ what I wrote about what I've tried, think about it a little bit, THEN respond. Geez.
Old Nov 19, 2007 | 08:52 AM
7901 WS6's Avatar
Did you spray the hell out of it with PB Lube, or Liquid Wrech, or WD-40. Do that and let it soak for about a hour. then attempt to get it out and give some more spray too. It is the rust that is holding it...
Old Nov 19, 2007 | 10:44 AM
jasonp31's Avatar
Yeah, thanks 7901ws6, that's what I'm going to try next. Other than that, I'll have to take it to a exhaust shop I think. If PB can't loosen it up, it'll have to be heated. I don't have the proper tools to do it. If I put much more torque on it than I am now, I'm afraid I'll damage the exhaust pipe or bung. Thanks for the help.
Old Nov 19, 2007 | 12:04 PM
Stroked96Bowtie's Avatar
I had a hard time getting one of mine off...used a torch and heated it up around the threads on the sensors and where it goes into the exhaust tube. Get it good and hot then hit it with a wrench....worked for me. Be aware where your fuel lines are when doing this.
Good Luck!
