custom grind
Old Nov 21, 2007 | 01:22 PM
Revelation Z28's Avatar
Originally Posted by speed_demon24
Sounds like you want a big cam to boost your ego, in that case this is pretty much the biggest off the shelf cam made for LT1's.
http://www.cranecams.com/?show=brows...tType=camshaft
240/244 .595/.595 on a 110 lsa....
nah i was just wondering what was the largest size everyone was running close to the MS4 size.
Old Nov 21, 2007 | 02:10 PM
slick1851's Avatar
You can run a big cam, it just depends on the person
I wouldnt mind DD a t rex but thats just me
I was daily driving a 3,000 pound car lol
slick1851's Avatar
I would just go custom
Old Nov 21, 2007 | 02:23 PM
z28misfit's Avatar
Originally Posted by rasputin
ls1's have different firing order so that would be a no no
i'm no expert , but how does the poster wanting the ms4 cam specs on an lt1 cam have anything to do with firing order? All he's wondering is if it is possible to run that duration, lift , in an lt1 motor.
Old Nov 22, 2007 | 08:03 AM
jakesz28's Avatar
You can run any lift and duration within reason. The results may not be worth the money. But I would have to agree that that cam works well in the LS motor because of the head ports and valve placements. Not the best chioce for us.
Old Nov 22, 2007 | 08:13 AM
joelster's Avatar
People get away with running big cams in relatively stock LS1's because of 2 things. The intake manifolds flow very well, and the cylinder heads flow EXCEPTIONALLY well for a bone-stock car. Yes you can run a big cam on the street without a problem, BUT you WILL need a good tune. The post up on the first page with the 3 cams listed for stock heads is a good idea. The comp 503 is great with stock heads. Firing order has absolutely nothing to do with picking a cam based on lift and duration. It does have everything to do with he 4/7 swap cams. A custom cam is never a bad idea. Keep in mind that your stock pcm poops out at 7000rpm.
Old Nov 22, 2007 | 09:23 AM
94Z28man's Avatar
If your interested in the cc306 like you said then I would say go for it. I had the cc306 long before I had my heads. The car sounded awesome and wasn't difficult at all to drive. The car ran a 12.6 without heads and a 12.1 with heads.
These numbers aren't all that great but I have yet to have the car dyno tuned, these numbers are off my own tunes.
Old Nov 22, 2007 | 12:52 PM
z28misfit's Avatar
Exactly what I was thinking.
Old Nov 22, 2007 | 05:36 PM
Taubr Unit's Avatar
I have the 847 cam and its deff. a big cam. Now i need to spend 2k on a set of heads to flow eveeerything it wants to. But i planed on getting heads anyways so it doesnt bother me in the time being.
Old Nov 22, 2007 | 07:02 PM
96lt1m6's Avatar
i would be more concerned about sounding like a 10 sec. car and running like a hotcammed car.its not a bad thing but still.
lots of people make the mistake of buying a cam that is listed at the bottom of a cam book page.....like i stated before its his car,he is dead set on a cc306 which to me is a cam that is OVERKILL for the relatively mild set up.
Shon Sherron runs 11.80s with a stock cam/heads w/weight reduction!
Stock Lt1 w/cam,gear etc.maybe run a 12.50
Old Nov 22, 2007 | 07:03 PM
werent you selling your car not long ago?
well when i get a tune, i should be 12.9/8 with boltons, which was my goal before. now im planning out my next step.
Old Nov 22, 2007 | 08:03 PM
  #32
Taubr Unit's Avatar
i still am in a way so its not that funny. But im not going to let it go for nothing. I dont have a crack addiction! So i guess im done helping you out.
Buy a HUGE! cam and sound like John Force and run a 13.8 and then act like a ricer and tell um ure v-tec wasnt working on that run!
Old Nov 22, 2007 | 08:09 PM
  #33
yea but you just mentioned getting heads, but you want to sell it still. i say when you get heads your mind will change as soon as that flexplate starts spinning!
haha 13.8 lol i dont have DOHC heads though!
Old Nov 22, 2007 | 08:13 PM
  #34
Taubr Unit's Avatar
well when i get my heads the price just goes up a little more, thats all. Everything i own is for sale for the right price.....
