Negatives of an iron-headed motor?
Any porter will charge more to do a cast head since it eats up more burrs and takes twice as long to cut. I hate porting iron heads. You're better off having a set of aluminums built for such a task, i.e. O-ringed. And you will definately want to use head studs, not bolts, if your "healthy" shot is above 200rw shots.
As for the motor, nothing different except maybe the crank pulley and the accessories. OH, and the style of opti in regards to the timing cover.
The iron heads can crack if heavily ported, few guys have had it happen after a couple years.
Far as I know the valve seats are actually able to take a bigger valve, but things like the pressed studs needing conversion add cost to using them. Would need to open up the pushrod holes too, really they are fine for mild work but if looking to make serious power the aluminums are the ticket.
For shortblocks though the b-bodies are a great budget friendly source and depending on the car less likely to have been abused as basly as an f-body motor.
