cam question?
--Alan
A 3.23 geared car will want something in the low to mid 220's (GM 846, CC 503, etc) on duration to accelerate the car very well. Great drivability while still giving an increase in HP and TQ.
Lloyd
A bigger cam makes more top end power but less low and mid range power. Just because some people make good power with a certain cam doesn't mean the car would not be faster or make more power with a different (and sometimes smaller) cam.
The more duration you run, the higher in the RPM range the HP and TQ curve are. A 240+ duration cam will wanna pull from 3500 to 6500-6800 RPM with stock heads and not make much power below 3500 RPM. As long as the car ahs some gear and stall to keep the engine in this RPM range, he will be OK with the way the car runs in this RPM. If he has to drive the car often and have the thing cruise around at a low RPM or want the car to accelerate very well at 1500-3000 RPM range (where most street driving is done), he needs a cam with less duration.
He can still use less duration and a tighter LSA to raise the dynamic compression so it makes more low and mid range power while still making the same top end power as that cam.
Next thing is will the stock bottom end last long at that RPM . . . . usually not. You are better under camming than overcamming and the "right" cam is always the best choice but most have no idea what the "right" cam is.
I am not sure of what he is wanting to do with the car, what kinda drivability he is willing to sacrifice, if he is running 3.23/3.73 gaers, what stall he is gonna run or if it is a 6 speed, etc, etc but the CC 503 (224/230 112 LSA) cam is pretty much a safe choice for any F body. It will allow a stock bottom end to last since you are shifting at 6200 RPM or so, can work with inexpensive springs, has descent drivability in all gears and any RPM.
If you have the 3.73 gears and 3600 stalla nd are willing to shift at 6500-6800 RPM, get the GM 847 cam and you will happier that the cam you have mentioned.
lloyd
