XFI Cam
Old Dec 1, 2007 | 10:24 AM
96capricemgr's Avatar
What irritates me is the way everyone just feeds ignorance rather than correct it. If I nicely say the right thing it will get lost in the 12 others who post the wrong thing.
Before you go talking up midlift numbers might compare to other heads, your midlift numbers are NOT that good.
Old Dec 1, 2007 | 10:58 AM
96LT1355Z28's Avatar
I agree there is a lot of bad info out there that just gets passed around. However "ported and polished" is a phrase that commonly gets thrown around and many people are just refering to what they've heard their dad's say. I've heard many old timers talk about "ported and polished" heads, they probably weren't poslished (or even ported for that matter) but I knew what they were talking about.
I was trying to say not to only look at the max flow as many manufactures advertise because it's misleading.
I never said my heads had great flow, I was simply giving him the awnser to his question.
Old Dec 1, 2007 | 11:43 AM
1989GTA's Avatar
96capricemgr: wrote:
"The XFI stuff is perfect if you want to be another sheeple buying mediocre parts that are "supposed" to be the best. Just make sure you are reallly good at making excuses about why it does not perform so you don't have to admit you made a mistake."
So what is the perfect cam for his car?
Old Dec 1, 2007 | 12:38 PM
Akira_X's Avatar
Originally Posted by 96capricemgr
Are you kidding?
Polishing is not something done by intelligent people looking for something in this range of performance. MAYBE really high rpm race stuff, but anyone who does it for the street is doing either as a marketing tool to impress the ignorant or is ignorant themselves.
xfi may be mediocre but so is almost everything else you get off the shelf, obviously something great would be good flowing custom heads and a custom cam to go along with it..
but for the mediocre off the shelf stuff I think xfi should be given a shot if not for the sheer fact that there isn't much info out there and not much numbers to boot.
Old Dec 1, 2007 | 11:51 PM
95Lwind05's Avatar
Are you kidding?
I never said i wanted to have the best of anything, and to be honest I will be happy if i get 330RWHP. Im not saying I know alot thats why im at a LT1 tech site, if i knew everything Id be doing this professionally and not as a hobby..thanks for riding my *** for just trying to learn, maybe since your so damn smart you should set me up with the perfect cam with in my budget and since polishing is retarded unless im going to be revving high maybe you want to tell me what to do there as well.
Old Dec 2, 2007 | 01:51 AM
hyperzone's Avatar
I was wondering whats the hooplah about with the XFI cam? What is the advertised bonus to having it vs. any other cam we've seen or heard about?
Old Dec 2, 2007 | 02:50 AM
Akira_X's Avatar
it's got more lift than the older cc's and supposedly it's better for fueil injected cars
thing is no one really has any solid numbers for them cause not many people have them
Old Dec 2, 2007 | 04:13 AM
1997bird's Avatar
Yep, COMP Is probably the best at advertising! Doesn't mean that they have the best product available though.
Old Dec 2, 2007 | 08:16 AM
The Engineer's Avatar
I'm running the Comp XFI-292 (biggest XFI), 1.6 RRs, beehives w/ AFR 195s in my 396 stroker. It's in my bracket car and I really like the cam, also very broad power band and I turn it just over 6500!
It runs 1.48 60fts, 7.00 1/8 and 10.83 1/4.
WD
Old Dec 2, 2007 | 08:28 AM
WD
Nice times! That's a bad *** picture.
Old Dec 2, 2007 | 12:39 PM
kinglt-1's Avatar
Nice times man! Hey caprice what do you have to say about xfi now!
Old Dec 2, 2007 | 01:00 PM
  #32
hyperzone's Avatar
Thats a WHOLE LOT OF MOTOR there.. not just the XFI cam doing that. Have any dyno graphs? did you ever run a different cam with the rest of your setup like that? Just curious...
Old Dec 2, 2007 | 03:06 PM
  #33
kinglt-1's Avatar
Yea but 10.8's na is pretty nice regardless!
Old Dec 2, 2007 | 04:03 PM
  #34
There are INDIVIDUALS who can make crap run well, MOST results I have seen from this line of cams suck. One car does not change that.
The IGNORANT believe super wide LSAs are necessary for the computer to be happy.
Old Dec 2, 2007 | 04:42 PM
  #35
SincalT/A's Avatar
Originally Posted by Akira_X
You think that cam would pass CA emissions with a tune?
I have not had personal experience with the xfi 280.I have however got the comp 306,lt4 hot cam to pass well under average emission with no smoke and mirrors.If you are worried about passing pm me with your setup and will try to help you out
Old Dec 2, 2007 | 05:17 PM
  #36
From what I've read about cams (many independant articles) the wide LSAs perform better with EFI applications. I don't think it is directly an issue of the cam related to the PCM, but the whole package (i.e., injection over carb).
WD
Old Dec 2, 2007 | 06:25 PM
  #37
fordeater's Avatar
just let people run it, it isnt you thats using it and has no effect on you. you seem like your about to pop a blood vessle in your head because people use an XFI instead of a custom grind. just settle down its only a cam....
Old Dec 2, 2007 | 06:31 PM
  #38
1989GTA's Avatar
Regarding the 280XFI cam we have a car here locally running a 355 motor that passes California smog. I'm running the 268XFI cam and no problems passing California smog. Almost forgot. We also have a 400ci motor car running the 280XFI cam and he passes smog. With a decent tune there will not be a problem.
Old Dec 2, 2007 | 06:59 PM
  #39
kinglt-1's Avatar
I was thinkin the same thing LOL!
Old Dec 2, 2007 | 07:21 PM
  #40
Sam Pace's Avatar
I have the 268XFI. With ported heads and a few other mods, I am at 350tq and 370hp. On a tune that is lean. Going for a final tune on friday. I will post the final results soon.
I don't see anything wrong with these cams.
