oil pump pickup
Old Nov 29, 2007 | 12:45 PM
fordeater's Avatar
Default oil pump pickup
How far is the screen supposed to be away from the STOCK pan, also how do you measure for this. need help trying to get this motor together and the oil system is really taking a long time. Thanks alot.
Old Nov 29, 2007 | 08:15 PM
fordeater's Avatar
wow nobody has ever put a oil pump in an F car?
Old Nov 29, 2007 | 10:18 PM
Biggin'89's Avatar
well you want it to be about a 1/4" so how i've seen it done and did it on my motor is put the pickup higher than what looks normal. then w/o the gasket set the pan on the block and push the pickup down. Now when you put your gasket on it will be that far off the bottom. Also its good practice to put a tack weld on the pump so the tube doesn't rotate or fall off.
Old Nov 30, 2007 | 12:45 AM
fordeater's Avatar
thanks man, ill do that tomorrow then get it welded
