Hydraulic Cam for 396!!
Not many guys make 490rw with big heads, cam and manuals.
I would doubt you make 500rw with a 355 at 11:1 on an LT1 style intake.
I'm looking at doing a 355, and would like to end up close to 500hp. I'm looking a the AFR 195, comp ported, 11.1 comp, and a lt4 intake, cam to me doesn't matter, I'm used to adjusting valves
It isn't my daily driver by any means but if I wanted to do it, I could with ease. My cam specs are 254/260 .62x/.62x on a 112. I haven't been on a dyno, only street tuned using a data-logger to fine tune it all. I'd estimate that my RWHP is in the 480~490 range and I'm taking it up to 7200rpm. Been trying to get to the track, but just haven't been able to find the spare time on the right day to go.
I think 500rwhp is doable, you will need an awesome set of heads, healthy amount of compression, and a cam to match it all. And I think a solid roller set up would be a must.
P
Car sounds good, by the way..
Well rwhp and fhp is to greatly different things, I'm looking at flywheel for my 355.
