Input with making a stock headed cam guide
There is more to cam and spring matching than just lift, the HOT lobes are very mild and even if those springs were good enough for it the more aggressive lobes of aftermarket cam will push them into float at even lower lift.
I think you mean that the guideplates will ensure that the rockers can't slip off the valve tips.
Good work on putting this together. It should help out alot of people if they actually read it.
I emailed Comp Cams and LPE etc. to find out what minimum size stall speed would be recommended for each cam and if for an M6 the gear ratio should be changed and got answers for all except the crane 227 and lt4 "hot cam" if anyone has anything to add to that.
Now my next question:
I'm going with the CC227 cam, Crane gold 1.6 RR's, CRN-10308-1 springs. Now my car has ~90k miles on it and I think it might be a good idea to change the lifters...but I dont know which ones to go with. Any recommendations?
Thanks
sticky it now!
Thanks
