View Poll Results: Which stall for my bolt on record LT1?
3200
16
34.78%
3300
2
4.35%
3400
9
19.57%
3500
3
6.52%
3600
16
34.78%
Voters: 46. You may not vote on this poll
For a Bolt on LT1 which stall?
Old Dec 9, 2007 | 11:12 PM
CamaroRacing12's Avatar
Originally Posted by joelster
A summer dd and a record holding drag car are two very different animals. GL with your quest.
oh i know that... for now it is a summer DD eventually it will be a record holding drag car... thing still has stock gears
Old Dec 10, 2007 | 12:33 PM
1SlowFormula's Avatar
Posting from experiance here...
I have had a 3500 Vig for over 4 years now, it could probably be refreshed but I am a cheep bastard. This was one of my first serious cost mods, I did all the free cheep stuff first then ran into tranny problems, when I pulled the tranny I figured that it was now the perfect time to do the converter, that and I could roll the cost into the price of the repairs and my wife wouldn't kill me for spending $700 on a car part...
As my daily driver I ran the 3500 stall behind a mostly stock LT1 running 2.73 gears for years and was in the 13.1 range. Last I finally came into the ability to spend more on the car and start putting more money into it. 3.73 gears and headers, rockers and exhaust got me into 12.5's. From there, I have tweeked the tune, done some weight reduction and suspension work to get me to 12.0's in the summer heat with 28" tires. I still have a lot of suspension tuning to play with and if I get a pair of sticky 26" tires, I should have a good contender for the record...
For those going to the LTXShootout, you can see it there for yourselves as I hope to get a few more things done before then too...
OK back to the post, YES you can DD a high stall car, NO you don't need 4K+ stall speeds on a bolt-on LT1, it all depends on what you want out of your car and what you are willing to live with...
Old Dec 10, 2007 | 05:34 PM
awesome post 1slow... honestly u are def a mentor to my goal... pretty much the reason im going to try for it eventually... so thank you for that...
but my question is would a 3600 stall be overkill performance wise? would it be too much stall and not work with the powerband to maxmize my performance?
Old Dec 11, 2007 | 11:29 AM
fast's Avatar
12.44 @ 106+ with 3.23s here (1.66 sixty)
using the vigilante 2800/3000 stall
bigger is NOT better for stall on an LT1
less weight, me tuning and 3.42s netted 12.07 (same stall)
Old Dec 11, 2007 | 11:44 AM
so bigger is not better? so what did u vote for?
Old Dec 11, 2007 | 11:54 AM
fast's Avatar
3200 :d
keep the weight down and work on the sixty
shon's #s are great, but can be duplicated or beaten
(incredible weather helps too lmao)
my credentials:
Old Dec 11, 2007 | 01:34 PM
u sure a 3400 wouldnt be better. fast?
and at the end of the year the racing weather up here in new hampshire is perfect... ecpsecially when the alt. is 58ft
Old Dec 11, 2007 | 05:16 PM
LittleRedZ's Avatar
i used 2800 with 3.23s with stock manifolds i ran 12.96@105.6mph with a 1.7860ft on a 17" nitto
Old Dec 11, 2007 | 05:24 PM
ScreaminRedZ's Avatar
registered user
I know that a 2800 sucked on my cam/bolt-on LT1. I had wished I had gone with a 3200+ stall.
Old Dec 11, 2007 | 05:36 PM
LittleRedZ's Avatar
3 things
1. You had a cam that changes torque curve
2. Your converter could of of sucked
3. your car could of had problems
Old Dec 11, 2007 | 06:13 PM
hmmm yea i dn... 1slow has a 3500 and is a record contender... fast had a 3200 and was a contender also... i think i may go with 3400 or 3300
Old Dec 11, 2007 | 06:24 PM
  #32
daniel6718's Avatar
3600 and 3.73 should be easy driveable and great shot at going for the record....
some1 one day will do 4.10 and 4500 stall or so and shatter the old record...wait some1 might already be doing that
Old Dec 11, 2007 | 07:48 PM
  #33
wouldnt the 3600 be too much stall and make me ge tout of my power band off the line?
Old Dec 11, 2007 | 09:42 PM
  #34
donkey mule's Avatar
Vig underates there stalls! I would bet true stall would actually be between 3200 and 3400.
Old Dec 11, 2007 | 10:11 PM
  #35
daniel6718's Avatar
no it wouldent....you want it to be about 1000 rpm before peak tq in a record ET situation a little closer to that peak tq is fine...enver seen a stock graph but i imagine tq peaks about 4k
Old Dec 12, 2007 | 09:20 AM
  #36
fast's Avatar
I won't argue that.
that's why I put "2800/3000" (PI pump #0 is what they call a 2800 behind an LT1 but I figure it's around 3000 . . . prob'ly 3400 in my cc306 car (same #0 pump vigilante)
more torque will make the stall higher
the 3200 (#6 pump?) would be a good choice if you want more than the #0 will give ya
I have PI vigilante's in both my LT1 cars
maybe some of the yank guys can chime in as well (or edge or performabuilt even)
Old Dec 12, 2007 | 02:50 PM
  #37
Vicious95Z28's Avatar
What's crazy is that people either voted the smallest or largest.
Old Dec 12, 2007 | 03:36 PM
  #38
Razor_Blade's Avatar
I won't argue that.
I have Performabuilt. They ask a bunch of question when you order and set the stall up for your application. Mine flashes exactly to 3000, which is what I wanted. Of course, it works so well that I now wish I had gone just a little larger...lol
Old Dec 12, 2007 | 08:31 PM
  #39
i think i may go with the 3400... im afraid to go with the 3600 because of losing my powerband
Old Dec 13, 2007 | 02:36 PM
  #40
what do u guys think?
