MSD ignition question
Old Dec 10, 2007 | 01:36 PM
kpetry's Avatar
Default MSD ignition question
Newby to the forum here...I have my LT1 out of the car and just back from a complete rebuild. The present Opti has 110K on it and works OK, but I think it would be best to replace it now while it's easy to get to and the engine is out of the car and the water pump off. I plan on replacing it with the MSD Opti, and I'm actually considering the MSD LT1 igniton kit which includes Opti, coil, wires, and control box - at $930 from Jegs. I definitely need the Opti, coil and wires, but I'm not so sure about the 60AL control box. Since my application will mostly be street/cruising, I don't feel I need rev limiting, and I think I can save myself $240 if I buy the items I do need seperately - without the 60AL. Can I / should I do without it, or is there something I'm failing to consider here?
Old Dec 10, 2007 | 01:39 PM
Disturbed Bird's Avatar
do the ls1 ignition pack conversion it will be much better
Old Dec 10, 2007 | 01:52 PM
kinglt-1's Avatar
I would just buy a new oem delco opti, msd wires, replace coil with a new stock unit. Unless you plan on running nitrous don;t buy the ignition box! Spend the money elsewhere. I am not convinced that msd is better than oem on newer vehicles. Today's igniton systems provide plenty of spark as long a thay are maintained.
