1.6rr??
Old Dec 10, 2007 | 02:48 PM
iroc1793's Avatar
Default 1.6rr??
Im getting ready to build my lt1 and i decided to go with the cc503 and the crane cams 10308-1 valve spring package, i want to also upgrade to 1.6 rr what should i use and do i need different push rods?
thanks for the help
Old Dec 10, 2007 | 02:58 PM
1SlowFormula's Avatar
You shouldn't need new pushrods if you haven't touched the heads or gasket thinkness, but whenever messing with valvetrain geometry it's always good to double check everything anyhow...
Old Dec 10, 2007 | 03:02 PM
kinglt-1's Avatar
+1 for above!
Old Dec 10, 2007 | 03:27 PM
iroc1793's Avatar
thanks, what rr do your recommend using?
Old Dec 10, 2007 | 03:56 PM
If you have the money, comp pro mags are really nice...
Old Dec 10, 2007 | 05:21 PM
iroc1793's Avatar
do you know the part number for them??
thanks
Old Dec 11, 2007 | 08:47 AM
97LT1's Avatar
thanks
there are 2 different part #'s because of two different rocker stud sizes.(CCA-1305-16 (7/16ths size rockers)) If you get the above part # rockers you have to get the matching studs below BTW
I would opt for 7/16ths rocker studs if your going to put in new rockers. (they are stiffer and flex less ,stronger.) ARP 134-7103
Old Dec 11, 2007 | 11:00 AM
iroc1793's Avatar
thanks for the help
