Any other boltons??
Old Dec 12, 2007 | 12:49 AM
thesoundandthefury's Avatar
Higher ratio rockers
Electric water pump
Mikronite rear gears
Did you ever get your PCM tuned?
Old Dec 12, 2007 | 12:51 AM
95CamZ's Avatar
Nope!that was the thing i was trying to see if i could do any other bolt ons before i bring it to thunder racing to get tuned right after christmas!
Old Dec 12, 2007 | 12:53 AM
TXFORMULA's Avatar
yeah, from what ive gathered, if you are going to mod and increase the hp it doesnt hurt and you can get one for 50bucks or less on ebay
Old Dec 12, 2007 | 01:00 AM
Black30thz's Avatar
+1 on putting that mass air flow screen back in, it is not restrictive to the incoming air especially w/boltons it is to make the MAF read more accurate. a 3200 to 3600 stall, trans cooler and a shift kit would be smart and so would suspension(lca and torgue arm, etc). do a little bit of research on the 10 bolt before you spend any money on it!
Originally Posted by 95CamZ
So it would be good to get due to lts,ory,lmI,(loud) causing more noise and vibrations making it pull the timing which is pulling hp??
yes
Old Dec 12, 2007 | 01:05 AM
95CamZ's Avatar
Thanks guys!!i'm going to put the screen back on and try to get some 3:42s and the lt4 knock module in before my tune and then i will post my #s as soon as i get it done!!
