is this true dual thing true?
It almost never happens (with any mod) that you get true a/b one change results that are well documented, too often other factors are in play too.
I'd love to see a true a/b comparison with dyno results of JUST changing from 2.5 to 3 true dauls with the SAME design, and with the distance one each side to the x exactly the same.
Folks, please remember too... it's damn hard to get the X dead center and the exact same distance from the collectors on an F-body. X pipes work great when they are set up like that (as you can easily do on a Vette) but not so hot when you have to have the x unequal lengths from the ends of the collectors.
-edit- removed pics and link... I have whored my setup out in other threads no need to do it here.
EDIT: PS Why not an H-Pipe? Not as efficient, but it still helps equalize the pressure for better flow. My 86 Suburban I had one installed and I like how it sounded afterwards
Hell, people even do mini H-Pipes before the Y-Pipe on stock exhaust just to help out every little bit. Being poor myself, it'd be something I'd do lol
