Metal Oil Pump Drive
It seems I remember some place selling metal tabs for the top of that dummy distributor shaft. I simply made a metal retainer plate out of steel from the hardware store, slipped it over the plastic piece, and used a longer bolt. Wish I had a photo...
I know about the little metal piece between the oil pump and distributor, I just haven't torn down an LT1
GM did some odd things in their span of SBC. Plastic toothed timing gears, that plastic oil pump collar... But, I guess a blown motor is good income lol
I basically just traced the top plastic piece onto a strip of (1/8"?) steel, and welded on tabs to keep it centered onto the plastic piece. I think I also used an old 1/2"-tall metal washer to fit down into the circular opening of the dummy distributor shaft, and welded that to the bracket as well. Drill a hole for the bolt, and you're in business. There's no way for the dummy distributor shaft to lift out of its bore, even if the plastic tab breaks, which it wont since it's braced.
To the OP, here's what the Melling IS-55E metal oil pump driveshaft looks like (which is apparently not what you were looking for). Top is stock. Left sides attach to the oil pump, right sides attach to the dummy distributor shaft.
It doesn't sound like he's looking for the oil pump driveshaft. He's looking for a replacement dummy distributor shaft (in the lifter valley) with a metal retainer instead of plastic. IE, this:
It turns out it was MorePerformanceInc that used to sell a steel retainer for this purpose. However, I recall they went out of business years ago.
Interesting. Looks like the difference between the 12550 and the IS-55E is that the 12550 is made of chrome-moly. The IS-55E must be weaker, though I've run it for years without any issues.
Yes, that is correct. I am looking for the replacement dummy distributor shaft in the lifter valley. So no one is making one anymore? I figured there would be someone out there that was making one!
I use a large washer to reinforce the plastic tab, (just in case the motor rattles-detonates-pre ignition).
Alex94TAGT fabricated his own custom reinforcement as mentioned already in the thread. Looks like a good peace-of-mind modification.
Karl Ellwein
Anyone have issues with the stub shaft on solid roller motors?
No, it is NOT the oil pump drive extension shaft being talked about here!
