wierd starting issue
Old Dec 30, 2007 | 12:05 PM
black383's Avatar
Default wierd starting issue
so i still cant figure this out... car sits for long periods of time, it starts fine... no issue... i drive the car around, park it then if i try to go start it like 30 sec later or 10 min later.. it barely starts... like it cranks really slow like it would with a dead battery.. it always starts but barely.. but if it sits for like hour or longer i cranks fine.. i had the alt. tested and it was fine and it has a brand new battery in it.. a cheap one, but still brand new... any thoughts? its basically only when car is hot and been driving.. otherwise its fine...
Old Dec 30, 2007 | 12:10 PM
FireSilverLullaby's Avatar
must be the stater, and if you have long tube headers the heat could of killed it.
Old Dec 30, 2007 | 12:12 PM
black383's Avatar
i was thinking that to... the speed shop i go to.. all they really do is F-bodies and they said they never seen the LT's heat the starter like that.. has anyone had that issue? is there a sheild i can get or have to fab one up?
Old Dec 30, 2007 | 12:13 PM
black383's Avatar
also.. when i cranks slow..the lights on the dash are all dim and stuff.. it acts like the bat is dead.. its weird..volt meter reads normal when car is running
Old Dec 30, 2007 | 04:29 PM
TXFORMULA's Avatar
check your battery terminals and the bolts holding them. i had the same thing happening and it was a stripped out terminal bolt. it would let it crank here or there but then it would sound like it was cranking slow as you describe most of the time. im not saying that is whats wrong with yours but check if you havent.
Old Dec 30, 2007 | 06:36 PM
black383's Avatar
i did check them.. they are nice and tight
Old Jan 1, 2008 | 08:44 AM
harvickgm's Avatar
just go to autozone or something and get an LT4 starter...alot of people have had great success with them..
