View Poll Results: which sub-frame connectors?
Weld-in
50
79.37%
Bolt-on
13
20.63%
Voters: 63. You may not vote on this poll
sub-frame connector question??
Old Jan 1, 2008 | 01:02 PM
fbodyfreek's Avatar
Default sub-frame connector question??
is there any real benefit to using either type (weld-in or bolt-on)? i notice that most weld-ins are a good bit cheaper, but the bolt-ons i could install myself. also i would think that the integrity would be stronger with weld-in because they literally become fused with the body. what do you guys think? thanks.
Old Jan 1, 2008 | 01:09 PM
1SlowFormula's Avatar
I have custom made chromemoly weld-ins that are only 10# total...
My goal with SFC's were to have the a good deal of strength and low weight, and this was the best way to accomplish that goal...
It all depends on what you are going to do with the car...
Old Jan 1, 2008 | 01:14 PM
fbodyfreek's Avatar
how much did those cost?
Old Jan 1, 2008 | 01:16 PM
fab and installed price was about the same as getting a MS off the shelf set...
Old Jan 1, 2008 | 01:18 PM
fbodyfreek's Avatar
cool, where would i go to have those made?
Old Jan 1, 2008 | 01:21 PM
I had them done in a performance fab shop in Maryland, but is was well worth trailering the car a few hours down there for it...
I don't think they are a sponsor here thought so I can't post the name in an open forum...
Old Jan 1, 2008 | 01:30 PM
fbodyfreek's Avatar
hmm... it's definitely something to look into. i'll see what i can find around my area. so they were the same price for a lighter weight? how much do off-the-shelf sub-frames weigh?
Old Jan 1, 2008 | 01:36 PM
If I remmeber when I was doing research a few years back.
MS - averaged about 20-25#...
CM - averaged about 15-20#...
more for the X brace types...
*** EDIT ***
I just looked at a few and it looks like the weights have come down, spohn is now 17.5 for MS and 13 for CM...
Old Jan 1, 2008 | 01:50 PM
infinitebird's Avatar
weld in for sure
Old Jan 1, 2008 | 01:51 PM
Badazz 97 TA's Avatar
buy bolt in and then have them welded. at least then you can enjoy them and not have to look around for a shop right of way to install them
Old Jan 1, 2008 | 03:40 PM
fbodyfreek's Avatar
sorry if it's a stupid question, but just to clarify CM=chromoly and MS="something" steel?
Old Jan 1, 2008 | 03:44 PM
Laffs's Avatar
MS = Mild Steel
IIRC
Old Jan 1, 2008 | 03:53 PM
onephatZ28's Avatar
+2 that is what I did.
Old Jan 4, 2008 | 03:34 PM
I found out that Tyson is a Sponsor here now so here is the info on who made mine...
https://ls1tech.com/forums/member.php?u=88442
Performance Auto Fabrication
Specializing in; Custom Roll Bars and Cages, Custom Exhaust, Custom Turbo Kits, Custom Fabricated Suspension Components, Suspension Tuning and Scaling, Fabrication/Welding for Street and Race Car Applications...New for 2007: Diesel Performance!!!
sales@performanceautofab.com
(410) 833-3713
http://home.comcast.net/~tfranklin5580/PAF/
Old Jan 4, 2008 | 05:03 PM
razorguy's Avatar
I just installed some bolt-ins onto my car and plan on having them welded at a later date. Bolting them on gives you 100% confidence they are exactly where they need to be. And unless under the car of a high HP motor, I wouldn't imagine the bolt holes stretching unless it's over an extended period of time..
Old Jan 4, 2008 | 10:50 PM
JonCR96Z's Avatar
Get weld-on SFCs. A muffler shop can put them in for you. And you can't put them in wrong.
Old Jan 4, 2008 | 11:59 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Weld 4 Sure.
Old Jan 6, 2008 | 09:00 PM
socal's Avatar
buy the cheaper weld-ons and take them to a muffler shop
Old Jan 13, 2008 | 12:49 AM
J_Z28_T's Avatar
Default heres another ?
If u put a cage in ur car do u still need sfc???
Old Jan 13, 2008 | 01:00 PM
96lt1m6's Avatar
YES subframes should always be installed..
especially if a roll bar or cage is installed you should have support along the rails and connecting the front to the rear..
