High Idle
Old Jan 1, 2008 | 03:52 PM
SpeedDensityZ's Avatar
Default High Idle
When I drive the car normally it idles like it is supposed to. When mash down on it and drive it hard it wants to idle around 1400 rpm. I checked the throttlebody and it is closing correctly. What other problems could it be?
Old Jan 1, 2008 | 03:57 PM
mean94lt1's Avatar
check the linkage on the tb i had problems with the shaft moving and the butterflys would stay open a little so i welded the 3 linkages on the tb together and havent had any problems since
Old Jan 1, 2008 | 04:29 PM
3pnt4maro's Avatar
IAC valve??
Old Jan 1, 2008 | 05:02 PM
The IAC is fairly new and I'm not getting any codes. I will double check the linkange and make sure it is working correctly and if that doesn't fix it I suppose it could either be the TPS or the IAC. I have replaced both and they have warranties on them so I can just swap them out with some new parts. Any other ideas??
