Need some help
I need some band clamps to attach my y-pipe to my headers apparently, what kind do I need? the preformed stepped ones or normal sleeve type?
My O2 extensions? Can I make my own by just extending the wire or do I need to order these for some reason?
And my cutout, I'm inserting a cutout in the 3" section, can I use the band clamps on these as well or do I need to weld the cutout into the pipe?
Any other hardware I might need, I'm trying to get everything I need to complete this in one setting.
-Rick
2. You need the O2 extensions, you dont have a single wire sensor so splicing will take more time and could lead to false readings.
3. I would weld the cutout in, less clamping means your less likley to have an exhaust leak. Thats me.
Tony.
