help a newb build a motor plz
on my dyno I made power upto 7200 then it flatlined and it fell off a bit to 7400.
I do plan to get a dfi but money is a bit of an issue right now and I am trying to set it up to spray it in the spring
from your first post:
I found a very knowlegable local engine builder who did good work for some of my friends in the past. I asked him if he would build a motor for me, and he said he would be happy to..... Problem is, he doesnt want to help me pick and choose parts. I can understand that cause he's a busy guy and has work of his own.
I don't understand an engine "builder" who doesn't want to have a say in parts selection for an engine that will be very high-end if you want 600 fwhp (500 rw). If it doesn't perform or worse yet fails because of parts choice, what does he say his responsibility is? Isn't his credibility on the line? You will be telling everyone who built your engine, right?
I hope you outlined your goals for this engine to him when you talked. How much did he quote for machining and assembling your parts?
Some folks here are trying to keep you from making a big mistake.
Again, build a 383 with an LE3 or Ai 200cc package on top and enjoy the car.
Best advice here. Read and consider carefully.
96CAPRICEMGR
Abare is a full blown RACECAR on fuel
The others I am not sure of, but would tend to be pretty radical.
Nonetheless, what this guy wants to do is HARD, make no mistake.
David
Mike's car is a full interior streetable car, definetely dialed in to race though high 1.3s with both tires over a foot in the air is proof of that, amazing site too see an Impala do that.
Alek's car is a street car http://camaroz28.com/forums/showthre...hlight=480rwhp , M6 certainly contributes to the high dyno. You are the second reply to the topic . Kept breaking drivetrain parts last I heard but 128mph is pretty good for all these too small parts people think have to be replaced to go fast
These are all little 2.00/1.56 valves, 200cc ports, lightly worked stock intakes.
I have said it before and will again I think people are way too quick to jump to comparatively exotic setup, converting gen 1 heads and intakes.
The results are right there, well proven and documented, they are just inconvinient to those with other ideas about how to reach a goal and therefore ignored.
IMHO I think the majority of folks who want to throw a number out there have little to no comprehension of what that number equates to in a vehicle. For a great example I would say look at the cost differences and the work it takes to shave 3 seconds off the stock times of 14.0 to 11.xx seconds. Now shave another three off that to get into the eights. I am not sure how many people have done that by now, but it is not many, and the costs grow exponentially.
To the OP :Simply stated I wouldn't go with Chinese metal for a high end build! They are what they are and they are inferior. Good for many but not all and especially not in that range. Again I would advise talking with one of the guys that have a proven setup with that kind of horespower, ask what they would have done differently, what it takes to maintain etc. My bet is that a true 400 rwhp car for several thousands less would suit you fine, way more than what is needed on the street, and competitive at the track. Just my .02.
They should be capable of building the shortblock, it is not that different, many will want to shoot WAY too low on the compression though, either need to educate them or tell them the chamber is bigger than it is and let someone else do the heads and bolt them on yourself.
When I first became interested in cars in the mid 90s all the magazines said 180-190 cranking psi was the max on pump gas, the b-body LT1 cranks 200 and runs happily on 87 octane, a heads/cam motor with upped compression can crank 230psi and still be fine on pump gas. The LT1 stretches a lot of the old rules despite being very similar to the gen 1 motors.
These days I see the car magazines as more comedy than infomation.
yup (notice my past tense "did" word)
