cc 306 cam???
Old Aug 3, 2003 | 10:04 PM
96-speed's Avatar
Default Re: cc 306 cam???
why would anybody get an auto anyways, what fun is that
Because they know they can beat me with 1/2 the power
My biggest issue with the auto/medium sized HR () is that I want more control of the rpms. Since you obviously have good info about it working just fine, I believe ya!
Ryan
Old Aug 5, 2003 | 11:54 PM
Vendetta's Avatar
Sup guys... just wanted to know what the name/number for my cam is... It's a comp cam, numbers are duration-214/222 and lift-488/509
Old Aug 7, 2003 | 03:08 PM
Mike TexaSS's Avatar
8 Sec Tuner
So what kind of power gains would you see on a 409 LT4 motor that is currently running a hot cam.
Has anyone gone from a HOT cam to a CC306?
Old Aug 7, 2003 | 03:52 PM
Gangly's Avatar
you would see A LOT. the RPM range is considerably higher, between 400-600 rpms, so you would need to spin the motor higher, but the power gains are worht it. I would estimate ATLEAST 15rwhp ACROSS THE BOARD. instead of going with the 306 cam, I would just do a huge custom grind that would go best with the 409. An LT4 Hot cam in a 409 is pointless, the motor will eat that cam up, spit it out, and beg for more. Its just way to small of a cam for a 409. I would go with something bigger than a 306 for a 409.
Old Aug 8, 2003 | 09:39 AM
8 Sec Tuner
Well i bet i might have the fastest n20 HOT Cam car out there. Its gone 11.1's @ 121 mph. In a 4400lb car!
Old Aug 8, 2003 | 01:48 PM
blackz93's Avatar
thats alot of weight!
Old Aug 9, 2003 | 02:00 PM
Vendetta's Avatar
Impala SS's are great... I always wanted to own one as a daily driver, hehe. Great time, man!
Old Aug 10, 2003 | 12:25 PM
Gangly's Avatar
Awesome numbers and the car is extremely fast, ive known of your car for a while here in houston and everybody says its crazy fast. Even though your knocking on 10's door, i still think there is a lot more to be had with a much bigger cam for your 409. I could be wrong, but they way i see it is that an LT4 hotcam in a 409, is comparably as big as a stock cam in a stock LT1. I think you could easily go bigger and see some gains, but if you didnt, you would still have the fastest late model Impala I have ever seen and thas freakin impressive in a 4400 lb car
