building 383
And you could make 410-430 with 28# injectors and 52mm, but if made statements like that about my products I also would over do the supporting mods just to guarantee the results.
What all do you have that makes such big numbers. The OP might be interested in your setup.
I'm not going to **** for distance here. I was simply trying to say if I were buying new injectors I would go bigger than 30's and I'm sure that more of your to notch builders would agree.
As far as my combo goes 383 stroker Brodix heads, good parts, good engine builder it's really that simple.
--Alan
--Alan
Congrats.
--Alan
--Alan
The popular combos were not well represented at the 2007 Impala Nats (St. Louis). Previous years had LE represented well by Glen Koenig and the 306 cam represented well by Andy Nick.
2005 stock bottom 350 with LE/BRE combo Glen Koenig
http://karl-ellwein.org/Pocono2005/supernatural.htm
2006 with 354 and LE/BRE combo Glen Koenig
http://www.karl-ellwein.org/Indy2006/supernatural.htm
The 306 cam in a heavy car and stock bottom 350LT1, Andy Nick, at steaming heat stroke hot Tulsa raceway 2003,
http://www.karl-ellwein.org/Tulsa200...pernatural.htm
2007 Glen Koenig ran stock heads/cam.
If I did not bring my road race super charged car, what do you think my DGGM would have ran in 2007 at St. Louis Dwayne? (with the 227 cam, with the 846 cam, with the BRE cam?).
How can any of those combos be inferior when they run so well in real life in black and white with time slips to show? You think you could have squeezed a 12.3 with light wheels and dropping the exhaust to match ol' Stumpy Glen Koenig's performance at Island in 2005? As strong as your heads/cam combo is right now I think it would be out gunned by Stumpy's old combo.
I am an Ai supporter and user but I firmly believe that LE and BRE are excellent heads/cam combinations and the bashing of them is wrong and mean spirited and for the wrong intentions.
Maybe it bares noting too that Mike Harris's NA AI topped 383 car ran what .6 faster than your blower car in St. Louis how big a stroker is that?
Glen Koenig wieghted 4030 at Island with 70 degree weather Total seal rings in that "stock shortblock" an electic WP worth .1 and a coated intake manifold you endorse as being worth what .1-15, and has publically said he questions the streetability of the valvetrain.
Your car is an engine test mule(Karl is an engine builder and competitive bracket racer) not a daily driver, last you raced it weighted what 3800lbs, mine is a true street car that actually sees many daily driver miles and has a true stock shortblock not the rebuilt ones and built motors you want too compare mine too.
I think it is quite irresponsible of you to misslead these other folks about your setup, are you honestly claiming those Comp 3192 lobes you are running are safe and prudent for a street car? Thing has more lift with 1.5s than mine does with 1.6s, your shaft rockers are likely a big part of what is allowing it to work rather than break stuff as it has for so many others.
Before you went back and edited your posts about it I looked it up
106LSA is a joy on the street right?Here are details for the discussed cars and setups.
http://dan.esteban.com/impalass/Retu...&CompareID=437
It is flattering for a carpenter with a street car to rattle an engine builder and competitive bracket racers with race cars the way I seem too. I must be doing something right?
On the shortblocks I find it interesting how you compare rebuilt motors too mine that has ever had a bearing cap pulled, that is a level playing feild right
.How come you left out the comparison too the 3400lbs with driver car this time, it's just 700lbs, means nothing?
You'll ignore the well performing AFR headed Ahart combo and minimize anyone's accomplishments attempting to shine light on your combo.
The only things about you that riles this junior engine builder is your condescending attitute and that you give kudos to your combo and ignore all the other good combos and you generally won't credit your source of learning.
No matter how much you think you are helping save the world and teaching people the proper way, being condescending and disrespectful to you fellow man will not get you to the finish line first.
But I do get a chuckle every time you bring up racers advantage over you. Really, I get to smile instead of steam whenever you say that. Test-n-tune is what you do and that is the path to going quicker. If I could test-n-tune instead of bracket race I could experiment and go even quicker and I long for the days of test-n-tune. It's fun.
Karl Ellwein
I e-mailed Jeff Creech and he wrote back in less than a day which really impresses me. He had some good things to say and I will continue talking with him on the motor. Thanks to everybody who had some advice.
Oh Caprice by the way...Jeff said the cc306 is a good cam, and suggested going with possibly a smaller cam.
I was with 1st Marine Div. 2/11 Delta @Camp Horno "The Walking Dead" in the 80's. An 0311, and I miss it.
Anyways, good luck with your rebuild. And remember to keep your head low when your out there in the trench. SEMPER FI,,OORAH and all that good ****!!!
Remember all my cam only car ran in a negative DA was 13.2, Glen made his car run 13.4 at a 4000ft DA, that takes some skills and work, skills I don't have and work I don't put into my car. In his hands I am confident my car would need a rollbar.
--Alan
http://www.victoryracingengines.com/...TX&BLOCK=SHORT
specs:
Eagle 4340 3.750" Crankshaft
Eagle 6.000" H-Beam Rods
SRP Forged Pistons
Perfect Circle Piston Rings
Clevite Rod Bearings
Clevite Main Bearings
Clevite Cam Bearings
ARP Main Studs
Fully Machine Block w/Deck Plates
Balance Rotating Assembly
Assemble Short Block
going to stick with her stock ported heads and the cc306 cam.
anybody have any idea on what dyno numbers or track times we should expect with this set up?
What do you guys think?
