Serious oil problem. Need pro advice
Old Jan 7, 2008 | 09:43 AM
Z284U2TRY's Avatar
Default Serious oil problem. Need pro advice
Ok long story short 94 lt1 auto was showing low oil pressure. idle cold it is 60 psi. hot it is maybe 5 psi. Checked with a mechanical gauge and it shows the same as dash gauge.
Change out pump yeterday and the same problems. This things runs like a beast and builds up to 60 psi wot. No noise from the bottom end or anything. The pan was spotless when chaniging pump.
What do i look for next guys? I am at a loss?
checked the new pump with a mechanical gauge and its the same deal.
Old Jan 7, 2008 | 09:51 AM
Z28Camaro30Ann's Avatar
What id your oil level like? Are you leaking any at all? What about coolant? Any oil in coolant or coolant leaking?
Old Jan 7, 2008 | 09:55 AM
Z284U2TRY's Avatar
No coolant leaks
the engine has 80 thousand miles
the oil leavel stays normal as well as the coolant.
This thing doesn't smoke anything either.
Old Jan 7, 2008 | 10:00 AM
I think you may have a bad oil sending unit...
Old Jan 7, 2008 | 10:09 AM
Z284U2TRY's Avatar
thats not it because the mechanical gauge shows the same as the dash gauge.
Old Jan 7, 2008 | 03:36 PM
buffman's Avatar
excess bearing clearances... What kind of mechanical gauge was it verified with?
Old Jan 7, 2008 | 04:12 PM
Shawn @ VA Speed's Avatar
I would agree that you have excessive bearing clearance.Probably main bearings since you dont have any engine noise.time for a rebuild
Old Jan 7, 2008 | 04:26 PM
1997bird's Avatar
Originally Posted by Z284U2TRY
No coolant leaks
The late model LT-1's have been notorius for having low oil pressure with the oil hot at idle. According to Melling all you need for oil pressure is 10 psi per every 1,000 rpm. Is the oil pressure drop a new problem or one that has been this way since you owned the car?
Old Jan 7, 2008 | 05:11 PM
csjta2's Avatar
Now that's funny.........
Old Jan 7, 2008 | 05:13 PM
Z284U2TRY's Avatar
Used a autometer mechanical.
I was afraid it was bearing related almost 0 psi and the car has been driven like this for a month. Its a fairly new problem. This car has not been miss treated and doesn't even have a mod on it. I was thinking if it was bearing would I not have seen some in the pan?
Thanks for the help
Old Jan 7, 2008 | 05:28 PM
1997bird's Avatar
If it is a fairly new problem then yes it probably is a bearing problem. As for being able to see particles in the oil pan, you would have to look at things with a microscope to see the brass bearing material. You probably could "roll" a new set of main bearings into the motor fairly easily in order to get the oil pressure back up. You might do a compression check and a leak down test before determining a complete engine rebuild.
Old Jan 7, 2008 | 08:04 PM
letsrun97z's Avatar
same thing here i was going to do new oil pump as well im so tired of this car i have a magnitic drain plug and never picks up anything oil is always farly clean
buffman's Avatar
if you want to check ppm for wear metals a $22.50 oil analysis will usually do the job
Old Jan 7, 2008 | 10:22 PM
letsrun97z's Avatar
who would do that? test. i know for our drill rig samples hyd fluid was shipped out and almost 200 to test
Old Jan 7, 2008 | 11:51 PM
RallyBoy's Avatar
blackstone laboratories---check them out. sending mine in tomorrow and i will post results.
Old Jan 8, 2008 | 05:53 PM
buffman's Avatar
prolly 1000s and 1000s of people do. Places like Blackstone do Oil Analysis.
Old Jan 10, 2008 | 07:22 AM
MIGHTYMOUSE's Avatar
have you tried any different oil(s)
can you increase the pump base pressure with some mod to it?
Holly's car had low idle oil pressure and has 200k on it. I certainly wouldn't rebuild untill you get some noise out of it at least.
james fyi your sig is wrong now and you also don't have an RPM link
Old Jan 10, 2008 | 07:40 AM
ckyconan2003's Avatar
throw some heavy weight oil in there , you'll be fine. this started happening to my camaro after i cammed it. THe higher weight oil will fix our problem for the short term or atleast till you have the money to rebuild. Castrol 10w-40 or 50, w/e's highest.
-Chris
