Best Lt1 head gaskets
DO NOT put FelPros back on. Call SDPC and get some Cometics. Those and some ARPs. I am coming out of the hole on a #82 jet and took out my FelPros. All the big boys told me to go to Cometics.
BTW If you lower the compression you just have to run more juice to make up for it . No myth there
As mentioned earlier, Cometic gaskets require a specific "smoothness" on both the cylinder head and deck of the block. Unless you know for sure that they have been machined with this in mind, I wouldn't choose the Cometics for a replacement. Most people have choosen Felpro 1074's and don't seem to have any problems with them. If it is feasible, I would consider head studs and pay close attention to ARP's torque procedure AND the recommended lube to use on them...it makes a tremendous difference.
The "impala" .029 gasket might be worth considering if you do want to try and get quench right.
Cometic has a .027 IF the surface finishes are perfect, they have a lot of options actually.
I listed the .026 gasket PN above but I don't know if I would try and pull quench down that far.
You running a dedicated system for enrichment fuel?
If you go too a small dedicated system you can use a low pressure carbed deadhead style pump and regulator for reasonable money and put as high an octane unleaded as you can find in there.
That was a thick gasket you were running, any idea on the bore. Wondering how much compression will be raised going too a thin gasket.
How do I prepare to use Copper Head Gaskets?
We recommend that all copper head gaskets be installed on engines with machined "o-ring" grooves and stainless steel wire o-rings. This groove is traditionally done in the engine block. Typical wire diameter is .041" in a .039" wide x .029" deep groove resulting in a wire standup of .012". This is used in combination with a .040" thick copper gasket (about 4 times the wire standup). For engines at or above 3 HP per cubic inch of displacement, the combustion seal should be enhanced. For this we recommend a receiver groove opposite the o-ring, typically in the cylinder heads. See your engine builder for other options and machining details
What surface finish is required to us an MLS head gasket?
A surface finish of 50 RA (roughness average) or finer, is recommended for a proper gasket seal. Anything rougher may conflict with the gasket design.
You said you were using a "copper head gasket" from Flatout. Is the block o-ringed for this style of gasket???
Running a quench height of .035 means gasket thickness of .028. That means SCR is gonna be 13:1, which don't really mean **** if your DCR is in check. And the added detonation resistance of low quench height means less head lifting (assuming that the heads are lifting and that it is caused by detonation). You better get your degree wheel and dial indicator out. And lets hope that you don't have to turn it so far back that it causes your other valve timing events to be out of whack. I'll come down and help you if you'll put my clutch in while I'm there.
Or at least that's thw way I'm doing it.
Man three months to go. Times running out and my wallet is alot thinner.
