Qustion
Old Jan 10, 2008 | 07:58 PM
letsrun97z's Avatar
Default Qustion
lets say when we drop my motor to do the oil pump and pan how likly is it that i'LL spin a rod or mains if i took the cap off the see the wear then torque it back down? Im thinking it would because of bolt strech maybe or from being disturbed im starting to gather parts for a rebuild in about 8 months (new job and moving out)
Old Jan 10, 2008 | 08:00 PM
CRAZZ28's Avatar
If you are rebuilding in 8 mos then dont even take the chance. IMO
Old Jan 10, 2008 | 08:03 PM
J_Z28_T's Avatar
Default ???
i agree to man just put the pump in and go, sucks to have the motor out though and have to pull it again in 8 months but its no biggie i got mine out now messing with it lol!!
Old Jan 10, 2008 | 08:07 PM
letsrun97z's Avatar
well i mean while im there im curious now just becasue the oil pressure. if it is really that bad i could spend 300 and get a new crank and stock berings for now.
Old Jan 10, 2008 | 09:31 PM
J_Z28_T's Avatar
Default oil press
have u did the oil cooler bypass that jumps the pressure up real good!!!
Old Jan 10, 2008 | 10:04 PM
letsrun97z's Avatar
97 dosnt have an oil cooler
CRAZZ28's Avatar
what kind of oil pressure are you seeing?
because honestly if you are going to go through the trouble of doing a new crank and all of the lower bearings then just rebuild the engine. Thats y i said just dont worry about it because the money you spend now is wasted in 8 mos when you do a complete tear down. throw heavier weight oil in it. 8 mos is like 2-3 oil changes. limp it by and save more money to throw into the total rebuild.
Old Jan 10, 2008 | 10:09 PM
fergymoto's Avatar
Pulling the cap off to inspect will not hurt anything. Just torque it properly when you put it back on.
J_Z28_T's Avatar
ill stick to my 94 lol!!
Old Jan 10, 2008 | 10:29 PM
letsrun97z's Avatar
well warm it stays 5psi when it gets to 180 in town stop n go i flip the fan's on and it will go back to bout 162 where it like's to run and psi will be about 3psi when stoped. start up is 50ish wot hot will get up to 45 # 5500 but no higher than 45# motor is so strong no knocks pings change the oil every 2k or less bad habit?..maybe. i use PP 10w40.. 15w40 a lifter starts clacking but pressure will stay 13ish when whrm-hot sending unit has been replaced
Crazz28 well i have 400 to get crank and berings but i dont have 2500 i would rather waite and everthing will be fresh i dont want to speen no more than 2500-3000 im going to go talk with an engine builder tm (to see if he has done and Lt1's)
Old Jan 10, 2008 | 10:56 PM
CRAZZ28's Avatar
thats what i meant.lol there is no point in getting into the motor that deep when you are just going to have it redone in 8 months. Do you have a mechanical oil pressure guage or is this comming from the stocker in the car?
Old Jan 10, 2008 | 11:17 PM
letsrun97z's Avatar
stocker was the same with the old and the new maybe ill just go to autozone and get one its the same thread as the standard gen1 screwin right
