noob Lt1 project
Old Jan 11, 2008 | 10:53 AM
haperry678's Avatar
Default noob Lt1 project
OK so I got the engine all torn down and ready to go to the machine shop. I pretty much know what direction I'm wanting to go with it just looking for some advice from the ones that have been down this road before. This is the setup I'm looking at:
355 LT1
Hotcam kit
1.6rr's
Comp pushrods
ls7 lifters
OEM replacment opti
MSD blaster coil
MSD wires
NGK tr55 plugs
Pacesetter LT's
ORY
Flowmaster cat back
Lingenfelter CAI
Port mached TB
Air foil
!air
!EGR
!cats
2800 stall
3.73's
255 fuel pump
and a good tune
I'm hoping to get around 320HP at the wheels. I dont know if this will be enough to meet that goal but I hope to be somwhere in the neighborhood. Any advice or constuctive criticizm welcome.BTW I will keep this engine N/A no spray or boost whatsoever. Thanks.
And yes I know the body kit blows
Old Jan 11, 2008 | 01:45 PM
haperry678's Avatar
No takers?
Old Jan 11, 2008 | 02:40 PM
99.9percenter's Avatar
Deck the block and run a lot of quench and compression. Ugraded fuel pump is not needed at this level. Injectors (MAY) be needed if you get good porting on the heads. You are going to have a blast!!
Old Jan 11, 2008 | 02:44 PM
haperry678's Avatar
I have to upgrade the fuel pump anyway because I'm going from a v6.
Old Jan 11, 2008 | 02:49 PM
COD02SS's Avatar
Get a custom ground cam. If you're going to do a cam do it right
Old Jan 11, 2008 | 03:07 PM
FASTFATBOY's Avatar
Throw that "hotcam" kit in the lake where it belongs...there are better cams off the shelf.
"Port matched throttlebody" Whats that?
You need a 52mm TB
The catback is ok, take the dual outlet flowmaster muffler and throw it in the lake with the hotcam kit, put a single in/out muffler of your choice with a single outlet dump on the drivers side of the rear bumper. I recommend a Magnaflow, Borla, Hooker Aerochamber, Dynatech Splitflow muffler.
Stock fuel pump is fine
Put more converter in it with a lockup
If you already have a 3.23 or 3.42 gear leave it alone.
My opinions.
David
Old Jan 11, 2008 | 03:45 PM
J_Z28_T's Avatar
355 LT1
Hotcam kit
1.6rr's
Comp pushrods
ls7 lifters
OEM replacment opti
MSD blaster coil
MSD wires
NGK tr55 plugs
Pacesetter LT's
ORY
Flowmaster cat back
Lingenfelter CAI
Port mached TB
Air foil
!air
!EGR
!cats
2800 stall
3.73's
255 fuel pump
and a good tune
here is a lil advice, or how i had my old lt1 see if this helps u!
stock bottom 350
stock roller lifters
stock intake and TB
stock injectors
stock pulleys
home made c5 k&n intake
cc306 cam
1.5rr
hardened springs and pushrods
guideplates
msd coil and wires
GM opti
tr5's
mallory 685 box
pace setter lt's
true duals, with bullets
walbro 255, no hot wire kit-but get one!
all emission **** deleted
6 speed
4.10
lca, relocation brackets
stock lifetime warranty clutch
maddz28,com tune
This car made 356 rwhp, 360 rwtq
Hope this helped u and gave u an idea, ur car is a auto so it will be a lil diff
Old Jan 11, 2008 | 09:04 PM
haperry678's Avatar
stock bottom 350
stock intake and TB
stock injectors
stock pulleys
cc306 cam
1.5rr
guideplates
msd coil and wires
GM opti
tr5's
mallory 685 box
pace setter lt's
6 speed
4.10
maddz28,com tune
What springs were you using? Do you have part #?
Old Jan 11, 2008 | 09:13 PM
95 bright teal's Avatar
If your putting in a stall and gears, i would also step up to a larger cam either custom or the popular cc306 or the gm847, i think those would work better with your mods and put you well past 320hp
Old Jan 11, 2008 | 09:36 PM
J_Z28_T's Avatar
Default springs
i dont know the part number, i bought the motor together for $1700 came out a friends car with auto and 3500 stall i believe he went 6.90-7.00 on 125 shot with this set up in his car! The funny thing is it only made like 280 rwhp in his car with the stall and auto! I was a lil off, but here is his signature the old set up was the motor im talking about-it had alot of wins lol!!!
94 a4 artic white z28...
old setup...295hp..312tq...1.60 7.60@90.0 (cam only) n2o 1.50 7.05@99 (cam+125)
new setup..360hp 390tq...1.85 7.65@92.5 (cam only) n2o 1.68 6.84@103 (cam+125)
(first stage 125 shot) (both 2nd kit (75-100 shot) and traction will be comming soon)
Old Jan 11, 2008 | 10:06 PM
haperry678's Avatar
How bout a comp XFI 260 cam with Comp Mangum 1.6rr's and Comp hardend pushrods? I still dont know witch spring kit to go with. Open for sugestions.
Old Jan 11, 2008 | 11:03 PM
J_Z28_T's Avatar
Default cam and srpings
I dont know much about that cam, u pretty much cant go wrong if u decide against the hot cam though lol!! Search the forums good!
Old Jan 11, 2008 | 11:11 PM
Schweet97Z's Avatar
you have a pretty good set up. listed there. ur goals arent set high, which is nice. you want a nice streetable car. the hotcam has been around for years and has proven itself to be a decent low budget street cam....but there are now better off the shelf cams out there that will net you more power and be just as streetable. if i were you though id talk to lloyd elliot about a custom grind for your setup, and consider a 32-3400 stall. also ditch the flowmaster catback, and get a hooker or magnaflow. other than that, your setup looks pretty good to me.
Old Jan 11, 2008 | 11:42 PM
haperry678's Avatar
I'm going to ditch the hotcam and go with a comp XFI 260. Will this work with the crane 10308-1 spring kit and comp magnum 1.6rr's? And also do I need a hydraulic flat-tappet or hydraulic roller for my allipcation? Please escuse my ignorance for I'm a NOOB.
Old Jan 12, 2008 | 01:43 AM
J_Z28_T's Avatar
Default noob
for a noobie u can spit those numbers out pretty good lol! It just takes a lil research, cuz ur not always going to hear what u wanna on here!
Old Jan 12, 2008 | 02:25 AM
infinitebird's Avatar
nice upgrade, the comp 260 xfi is even smaller than the hotcam lol.
And you need hydraulic roller.
Old Jan 12, 2008 | 02:31 AM
Schweet97Z's Avatar
Edit: IB beat me to it....lol
get a CUSTOM ground cam and be done. Spend the extra 50-100 bucks.....
