Hard starting, randomly.
Old Jan 12, 2008 | 03:20 PM
946spdz's Avatar
Default Hard starting, randomly.
Alright so lately my car has not been able to start, it has only happened about 4-5 times in the last 7 months and i really just dont want to worry about my car not starting. When i try to start it, the car just cranks and doesn't fire till about 3 straight minutes of cranking and holding the pedal to the floor, and during that time it will chug up to 100 rpms then finally start and missfire for 10-15 seconds then run perfectly again..... so ive been reading and ive come up with leaky injector, ICM, and fuel pressure regulator... please help, what do you guys think?
Old Jan 12, 2008 | 03:28 PM
Jditlfm's Avatar
put a fuel pressure gauge on it and go from there. The results of that test will determine a lot
Old Jan 12, 2008 | 03:43 PM
946spdz's Avatar
alright, and it smells like gas when im tryin to start it, so i thought it might mean it had no spark... ill try that if i can get a hold of a gauge, any other suggestions?
Old Jan 12, 2008 | 04:44 PM
Jditlfm's Avatar
it could also be the opti on its way out. Try this test listed on this page.
http://shbox.com/1/4th_gen_tech2.html#opti_test
Old Jan 14, 2008 | 12:08 PM
great421's Avatar
Another Opti vote!
Mine acted very similar - long starting times for about 4 months then Pop! The Opti low res signal (DTC 1371) just died driving down the road, steady, state at 70 MPH. Replace it now before you're stranded!
Old Jan 14, 2008 | 04:01 PM
ricknbird350's Avatar
its your ignition switch mounted half way down your steering column.
happened to me to it only gets worse.. noone was a help i just decided to replace it one day and found the old one burnt lookin
