gm 847 specs
Old Jan 13, 2008 | 02:02 PM
infinitebird's Avatar
Originally Posted by daniel6718
lol like the guy above said let him do it and he be rebuilding it in a few months...he can put it in there but he needs to shift at 7000....
with stock heads you aren't going to be making any power shifting there.
That's where the cam wants to make power, but without better heads it ain't happening.
If you are going to run this on a stock headed car I wouldn't shift it much over 6500.
Old Jan 13, 2008 | 02:25 PM
J_Z28_T's Avatar
Default 847
thats up to my friend, his motor im still unsure what i want to do. I really want the le2 and i just bought my guide plates and 1.6rr for a nice deal! so i just need to fig out what i want to do with the heads and cam!
Old Jan 13, 2008 | 02:34 PM
SmokedOutZ28's Avatar
My car made power to about 6500-6600 shifted it at 6800
Old Jan 13, 2008 | 02:56 PM
J_Z28_T's Avatar
i just talked to him again and he said he liks the way the 847 sounds thats why he wants it lol! he is really a friend of my room mate so i can call him a dumb *** lol!
i think im just to wait another month and go with the le2 ill have the money by then
Old Jan 13, 2008 | 04:03 PM
Schweet97Z's Avatar
if i could have done it all over again, I would have gotten the le3 or le4 cam.....his cams are the ****.
Old Jan 13, 2008 | 04:30 PM
J_Z28_T's Avatar
Default le3
so its worth spending the lil more and going with the le3
Old Jan 13, 2008 | 04:46 PM
Schweet97Z's Avatar
absolutely
Old Jan 13, 2008 | 05:19 PM
J_Z28_T's Avatar
Default le3
Cool its not that much more $$, and i already have a intake ported by him but ill have to have it matched for the le3
daniel6718's Avatar
le3 lloyd says wont work with stock valve reliefs...
847 will make power up there as will any cam...look at ls1's...its just is it worth it?
josh what kinda stuff did you get pm me
Old Jan 13, 2008 | 05:22 PM
letsrun97z's Avatar
Nah your motor will bolw in like a month
Old Jan 13, 2008 | 05:31 PM
Schweet97Z's Avatar
its not about peak power....its about more power across the rpm band....an le2 car, will most likely lay down better times than what my car would, although mine would dyno higher....
Old Jan 13, 2008 | 10:53 PM
  #32
J_Z28_T's Avatar
how will a stock bottom motor blow with the le3, just by spinning it so high in the rmp's i guess. Going to be a fresh motor if it last 6 months ill be happy
Old Jan 13, 2008 | 10:54 PM
  #33
J_Z28_T's Avatar
pm sent bro
Old Jan 13, 2008 | 11:06 PM
  #34
You will spin a bearing with that cam if your motor has high miles.
Old Jan 13, 2008 | 11:26 PM
  #35
LT1Formula007's Avatar
I agree, spinning high rpm's on a stock bottom end with high miles will most likely cause you to spin a bearing....
Schweet97z and all of the others who responded to my question THANK YOU! for the answer. I thought that the LE3 was better than the 847. But just wondering what setup I'm really wanting to run. So far I have already decided to do a Forged 383 with 11.8:1 compression and a LE2 head/cam package and his ported intake, as well as all of the bolt ons...I hope it flat out gets it when I'm done....I'm wanting a low 11 second street car and I'll be content with it. Hell IF it's not what I'm expecting I'll go ahead and throw a Bigger cam in it and see what happens. I'm doing my Moser 12 bolt and Transmission next winter....Can't afford to do EVERYTHING this winter. Thanks again you guys
And the sound clips sound awesome!
James
Old Jan 14, 2008 | 06:55 AM
  #36
Schweet97Z's Avatar
It possible to spin a bearing....but I wouldnt go and say it will be spun with in a month....reving a stock bottom to the moon is a ticking time bomb for something to happen....but thats why I have my shifts set at somewhat on the conservative side...do a good clean install, run good name brand oil, and make sure the oil pump has good pressure....you should be fine for alittle while. But the key factor is CLEAN install....no dirt floors, make sure its in an enclosed garage, and just take your time.
James, Your welcome....also, bump that compression up to about 12.0-12.1. sounds like you got urself a decent build going there....however I think you should do rear, and tranny before you do the motor....
Harold
Old Jan 14, 2008 | 07:10 AM
  #37
J_Z28_T's Avatar
Harold
Thanks man for ur time and advice-i agree on the clean install! My car supposly had a new motor when i bought it which was from a guy i know, but i knew what kind of work he does and its normally ****. So i decided to pull the motor and check and i was right lol!! Junk yard impala motor with the good ol iron heads lmao! so im going to run through the block and refresh it and look at getting one of the LE kits, do a double roller TC and role with it for a while. Im not looking for a record breaking car just a good track car and one day ill do the bottom. I am going to do ARP rod bolts though
Old Jan 14, 2008 | 07:24 PM
  #38
[QUOTE=Schweet97Z;
Harold[/QUOTE]
Yeah this is my first LT1 car and First 383 Build.... So i wanted to make it a healthy street car and Lloyd Elliot Kept telling me to go with 12:1 compression or there abouts, But I had my engine builder pick up a set of 11.55:1 Forged Pistons for my application b/c I was worried about detonation on pump gas, and before I ever heard of Lloyd Elliot. Once I heard of Lloyd I contacted him and he said that with his LE2 Heads it would take my compression up to 11.8 or so. But if I knew then what I've learned now I would've went with 12.0+ Compression. But I'm still not that far off from it. Plus my block is decked to zero and I may use a thinner Head Gasket to try and obtain 12:1. But I'm pretty sure I'll be content with it for now.
And as far as the Rearend and Trans goes; I'm not gonna put my motor in until mid to late summer so I'm only looking at having it running for a couple months during this summer, then doing the driveline next winter. So I'm not concerned with breaking a rearend or transmission. I have a spare rearend and a Good Friend who builds Transmissions. But thats gonna be next in line after the engine is tuned and up to PAR! Also once the Trans. and Rear is done. I'm doing a full UMI/BMR/Spohn Suspension setup. (The rear is gonna be a Moser 12 bolt with 3:73's. And the trans. will be a Built 4l60-e to top it off.) Thanks for the advice... I've been doing ALOT of researching to find a good setup! Thanks again!
James
Old Feb 16, 2008 | 05:55 PM
  #39
indirocz28's Avatar
234/242 .574/.595 112 lsa w/ 1.6 rockers.
Is that the spec's for the 847 im guessing?
Old Feb 16, 2008 | 06:38 PM
  #40
97LT1's Avatar
Yeah thats them.
With the LE3 package Lloyd told me you should run a -5cc piston to clear the valves if I remember correctly. I am really excited that my engine is finally coming together. I cant wait to post up some LE4 cam vids.
