gm 847 specs
Old Jan 12, 2008 | 10:42 PM
J_Z28_T's Avatar
Default gm 847 specs
Ok i searched and got tired of looking. My friend wants to know the cam specs of the gm 847, he does not have a computer. Can someone shoot me a link or a thread that has went over this, thanks
Old Jan 12, 2008 | 10:54 PM
Schweet97Z's Avatar
234/242 .574/.595 112 lsa w/ 1.6 rockers.
Old Jan 12, 2008 | 11:12 PM
J_Z28_T's Avatar
Default Cool
thanks man, ill call him and let him know
Old Jan 12, 2008 | 11:51 PM
LT1Formula007's Avatar
Man thats a pretty healthy cam....Be ideal for a 383 or 396 stroker huh!
Schweet97z: Which would make more power? The LE2, The LE3, or the GM847??
AND.... Is the GM847 pretty streetable? Or Not?
Old Jan 13, 2008 | 12:08 AM
redneck01's Avatar
the le3 would make better power in a stroker, since thats whats its designed for. the le2 make power sooner than the 847, but the 847 is a few years old but makes serious power from 3500 rpm on up.
anything is streetable with the right tuner.
Old Jan 13, 2008 | 12:53 AM
J_Z28_T's Avatar
Default ???
ok i gave him this info, and he wants to know if the 112 lope seperatrion is good for n20?
Old Jan 13, 2008 | 01:25 AM
daniel6718's Avatar
847 is not a good cam for a stock motor...
and any lob seperation is good for nitrous...some are better than other though
Old Jan 13, 2008 | 01:51 AM
Schweet97Z's Avatar
LE2 cam is compared to the cc306, the LE3 cam is compared to the 847, both making more power down low and haveing better numbers through out the rpm band over the "off the shelf" grinds. I am running the 847 in my car now...dont get me wrong, the car SCREAMS, however, you have to be prepared to rev the hell out of it. I have the car shifting at 6400 rpms....on the dyno we had the car going to 6800 and it was still making power. Im sure the cam would make power all the way until the pcm wont let it rev any higher. As far as streetability goes, its all in what you can define as streetable. I have no problems with it, but you need a high stall, and a 3:73/4:10 gear. The car will never see long cruises like it used to.
Old Jan 13, 2008 | 01:54 AM
Schweet97Z's Avatar
112 lsa is fine for nitrous....
Old Jan 13, 2008 | 01:55 AM
J_Z28_T's Avatar
Default gm 847
Im going to bring him by and let u talk to him daniel, i told him thats a big bitch! I tried telling him about the cc306 he said he wants something a lil bigger He is a guy that works wit my room mate at the bread place. What u suggest, he has all the bolt ons and 100 shot heads to come he said. He wants to run u lol! (full weight car)
Old Jan 13, 2008 | 03:07 AM
Taubr Unit's Avatar
I have this cam in my car also with a 3200 stall and 3.73 gears. I drive it on the street a lot and i dont have any issues. I do how ever have my shift points at 6700. I just dont care that much cause i dont drive it that much. And i dont care if the motor craps out cause its next on my list anyways. Here my idle clip for it too if u wanna hear it....
Old Jan 13, 2008 | 08:46 AM
Schweet97Z's Avatar
sounds good Taubr....here are some sound clips of mine....
http://youtube.com/watch?v=x765etWoy3M
http://youtube.com/watch?v=z379T6MFRWo&feature=related
Old Jan 13, 2008 | 09:12 AM
redneck01's Avatar
very nice genltlemen...i miss having my 847 in my 97 with the 383..guess ill have to get another one.
Old Jan 13, 2008 | 10:24 AM
SmokedOutZ28's Avatar
The 847 cam is very streetable I drove mine around for about 4 months before I spun the rod bearings.
Old Jan 13, 2008 | 01:20 PM
J_Z28_T's Avatar
Default gm 847
What about that cam with stock heads and 1.6rr
Old Jan 13, 2008 | 01:29 PM
J_Z28_T's Avatar
Default cam
The more my friend talks about this cam the more i want it lol! I wanted to the le2, but i dont know if i wanna drop 1750 yet plus the $$ 1.6rr. I can afford to go with gm 847 and 1.6rr, and make the stock heads work right now. Do yall think this is a good idea. I have a th350, and will have 3.42 with a welded-stock 10 bolt and all the suspension stuff. I wanna go wit a 4000 yank stall. Also, 150 or 175 shot DP on a new stock bottom motor. Any ideas yays or nays?
Old Jan 13, 2008 | 01:34 PM
infinitebird's Avatar
the 847 is not a particularly good cam with stock heads. They don't flow enough at the high rpm you need to make power with that cam.
Old Jan 13, 2008 | 01:43 PM
street demon2k3's Avatar
x2
Maybe a cam just a tad smaller (230/236, 227/233, etc...) that way you can keep the shift points under 6400 as well as a little more usable power.
Old Jan 13, 2008 | 01:52 PM
I used it with stock heads, Although I wasent taking advantage of it's full potiential with ported heads I enjoyed it while i had it. Made 353hp/358tq to the wheels N/A and 464/518 with 100 shot.
If your looking for something to last in your Stock shortblock while you save up cash for a rebuild or ported heads the 847 isnt the cam you want! The stock shortblock can't handle the rpms needed to run this cam. If I could do it again I would go smaller so my shortblock would last longer so i can continue to drive my car while I built the 396 rather then have it sit and be without the car. JMO
Old Jan 13, 2008 | 01:59 PM
daniel6718's Avatar
lol like the guy above said let him do it and he be rebuilding it in a few months...he can put it in there but he needs to shift at 7000....
