full bolt on lt1
Old Jan 14, 2008 | 10:46 PM
01gtmustang's Avatar
Default full bolt on lt1
my friend has a 93' z28 m6 and has full exhaust and cold air, under drive pulleys, short throw shifter and he was wanting to know what would be a good time for it at the track.....what do you guys think???
Old Jan 14, 2008 | 10:48 PM
J_Z28_T's Avatar
Default track
the m6 is going to kill his track time
Old Jan 14, 2008 | 10:51 PM
98lswonz28's Avatar
bolt-on record is a 6-speed car. 11.8? the record holder would be much slower auto style.
Old Jan 14, 2008 | 10:52 PM
98lswonz28's Avatar
should run around a 13.6-13.7 @ 103 if he can 60' 2.0 or better.
Old Jan 14, 2008 | 11:29 PM
daniel6718's Avatar
1slowformula i think is goana surpass the 6 speed record with an auto and good efficient converter
Old Jan 14, 2008 | 11:38 PM
95 bright teal's Avatar
yeah id say mid to high 13's if he caan hook well
Old Jan 14, 2008 | 11:55 PM
infinitebird's Avatar
If he can shift I think he should be able to do better than high 13s with full boltons.
Old Jan 15, 2008 | 12:01 AM
slick1851's Avatar
Rember he has a M29( I think thats the right code)
Its not a T56 and has shorter gearing in the 93,so this could help it
Old Jan 15, 2008 | 01:18 AM
gatorhead's Avatar
If it is a true full bolt on he should be well into the 12's, unless he needs a driver mod
Old Jan 15, 2008 | 07:40 AM
Puck's Avatar
He would be quicker with a stalled auto.
FWIW I went 12.8's bolt-ons and DRs w/ a 3200 stall. What you listed is not near "full" bolt-ons though.
Depending on driver and altitude maybe mid 13's?
Old Jan 15, 2008 | 07:52 AM
1mean96ss's Avatar
My car ran a 13.6 with just drag radials, now it has LT's w/ x-pipe 3600 converter, and LCA,s and a torque arm. After i put the stall in i ran a 12.97 i cant wait to go back i should be able to get around the high 12.7 range Hell i still need gears and a pully
Old Jan 15, 2008 | 08:05 AM
BOLO's Avatar
Is he running stock gear? '93 m6 came w/ 3.23. If he can shift and launch effectively, high 13's would be attainable.
Old Jan 15, 2008 | 08:10 AM
fast's Avatar
running 12s is easy (did it with stock converter . . .ok it was cold out lol)
[I can't find any of my old time slips (think '02) 12.4s w/ 3.23s, 12.0s w/ 3.42s and tuning]
running 11s takes some dedication
there are 10,000+ threads just like this one
slick1851 brings up a good point, but if I recall there were a couple of different 6spd's in '93 depending on rearend ratio as well
Old Jan 15, 2008 | 03:55 PM
Shon Herron's Avatar
11.80s is no problem!!
Auto might be faster in most cars but hard to beat Russ's rowing skillz....
alot of times after a run we were asked what auto trans are we running...
Old Jan 15, 2008 | 04:05 PM
wrd1972's Avatar
full bolt-on LT1 w/ gears better be in the low 13's with decent driver and 60 and 12's on stickies.
Old Jan 15, 2008 | 04:58 PM
With the mods listed he would need to dead hook to see low thirteens, unless there are more mods then stated i couldnt see it otherwise
Old Jan 15, 2008 | 05:00 PM
3pnt4maro's Avatar
I say low 13's
Old Jan 15, 2008 | 05:03 PM
StealthFormula's Avatar
With those mods I was running low to mid 13's so if he can drive it I'd say a 13.3-13.4
Old Jan 15, 2008 | 05:07 PM
Slowmaro95Z28's Avatar
I hit a 12.9 @ 106 with headers/off road y, catback, cai, 3.42's, and tune. This was with stock converter in my auto and street tires (275/40ZR17's). Anything's possible. Some cars just run better than others.
Old Jan 15, 2008 | 06:12 PM
LT1Formula007's Avatar
Hey man whats up? It's James!
Just so you know if you already don't, if your talking about Tommy's old car it has a 3.23 rear end in it with the m29 Trans. I was at the track with him when it was running like $hit. He ran a 14.2 with a bad 60' and with it falling on it's face at high rpm. With just CAI, CatBack, and UD Pulley's, and shitty tires. But with the PS LT's, ORY, new clutch I put in for Tommy, and the tune up it needed (Burnt Wires), & with some Drag Radials and a good driver.... it should be good for low 13's no problem. If you guys need any help with it LMK. I have a friend with a Ported 93 Intake for sale and a few other people with some things for sale.... Tell him I said Good Luck with it.
