What Is This Part And Where Do I Get It!?
Old Jan 15, 2008 | 12:53 AM
My25thTransAm's Avatar
Default What Is This Part And Where Do I Get It!?
I have had the most trouble getting this part. I have checked shbox.com which does not show the exact part (pic of 95 z28) I have a 1994 TA 25th Annv. and have no clue where to begin getting this. It is starting to leak(again) The part number I drummed up is #10262478 which shows no availibility. I will be very grateful for any help! THANKS!
Attached Thumbnails What Is This Part And Where Do I Get It!?-picture-084.jpg   What Is This Part And Where Do I Get It!?-picture-060.jpg
Old Jan 15, 2008 | 01:00 AM
TwoFast4Lv's Avatar
Actually the pic is of a 93-94 car(95-97 cars do not have them) and it is the heat hose set with the Throttle Body heater hose hook up
Old Jan 15, 2008 | 01:01 AM
chameleongreen97ta's Avatar
i know it is a cooling line from your water pump i think
Old Jan 15, 2008 | 01:05 AM
Where do I get this?
Old Jan 15, 2008 | 01:10 AM
gatorhead's Avatar
You can try a local salvage yard or dealer, or you can fabricate one yourself as most people do.
Old Jan 15, 2008 | 01:29 AM
Anywhere to order it (website)? Like a whole new heater hose kit? thanks
Old Jan 15, 2008 | 01:35 AM
gatorhead's Avatar
I am unaware of any direct replacements. Any local parts house will have hoses and fittings to make what you need.
Old Jan 15, 2008 | 05:11 AM
leadfoot4's Avatar
The dealer will have them. I replaced ALL of the cooling hoses on my '96 Z-28 about 3-4 years ago. The heater hose assembly is a real PITA, due to the metal bracket that attaches them to the car's frame rail. Since I consider hoses a wear item, I felt that after 9 years on the car, it was time for replacement. I checked the aftermarket first, but nobody offered them, so it was off to the dealer.....
Old Jan 15, 2008 | 07:50 AM
Paul Bell's Avatar
That's MISTER MODERATOR
GM hose kit 10236039. About a hundred bucks at GM Parts Direct. Bitch to remove the old one, even bigger bitch putting in the new one. Has the check valve, bleeder and fitting for the throttle body. This is for 93-94 cars only. For 95-97 cars, the hose kit is 10261147
Old Jan 15, 2008 | 09:38 AM
TwoFast4Lv's Avatar
What he said I had to replace mine a few years ago
Old Jan 17, 2008 | 10:25 PM
Thanks alot guys! An item number and a picture! w00t! I appreciate it!
Old Jan 18, 2008 | 02:51 AM
96mikez28's Avatar
Yep thats your Inlet/outlet from the heater core
