Crank ?
Old Jan 16, 2008 | 09:22 AM
BsGreenZ's Avatar
Default Crank ?
I was wondering if a gen one 400 crank will work in a LT1.. I have the bottom end clearanced already.. any thing else that i would need.. thanks
Old Jan 16, 2008 | 09:34 AM
matt94z's Avatar
You need to have a crank that is internally balanced and a 1 piece rear main seal.
Old Jan 16, 2008 | 01:58 PM
BsGreenZ's Avatar
are there any stock 400 cranks like that?
Old Jan 16, 2008 | 05:26 PM
96capricemgr's Avatar
You can use a old 400 crank but generally it is not worth the effort unless you have some nice trick aftermarket crank. By the time you grind it undersize to fit the 350 mains and buy the rear main adapter you are at the cost of the basic aftermarket cranks meant for this purpose.
Maybe Karl Ellwein will pop in, he has a stout motor he built like this and I believe he discorages others from doing it the same way. Works but is not worth the effort.
Old Jan 16, 2008 | 08:51 PM
BsGreenZ's Avatar
ok never mind then lol .. i'll just buy the after market stroker crank lol..
