Thrown rod
Old Jan 17, 2008 | 07:51 PM
93blacktransam's Avatar
Default Thrown rod
Well i think i threw a rod so what do i need to rebuild my lt-1 ?
Old Jan 17, 2008 | 08:10 PM
ecniv's Avatar
A stack of credit cards and the sponsor list to the right.
Old Jan 17, 2008 | 08:13 PM
98pontiacfirehawk's Avatar
Well, if you in-deed threw a rod mostly a block would be a good start. You need to pull the engine and check it out first to see what damaged has occured.
Old Jan 17, 2008 | 08:16 PM
kahunaking's Avatar
Well I blew up the motor in my 93 TA a couple weeks ago. There are chunks of piston in my intake manifold. Im just throwing together a redneck rebuilt rering and rebearing lt1 for now until I can build a 396.
Old Jan 17, 2008 | 08:32 PM
how much do i need just to get it back if its not as bad as i think ...i will be pulling the engine tomarow
Old Jan 18, 2008 | 05:06 PM
SLawson86's Avatar
depends on what is wrong and torn up.
Old Jan 20, 2008 | 09:26 AM
qwk93ta's Avatar
+1 it's not going to be cheap!
Old Jan 20, 2008 | 10:24 AM
kahunaking's Avatar
Hopefully yours isnt as bad as mine. There are bits of aluminum filling the intake manifold, Oil in the coolant, coolant has filled the exhaust. I have to throw away virtually everything except the intake manifold. Since I am putting new bearings into a stock shortblock its only going to cost me about 600 bucks total to get back on the road.
Old Jan 20, 2008 | 11:04 AM
v7guy's Avatar
I've spun a few bearings in a couple motors. I just bought another used shortblock. The problem being you never know what you're going to get or how long it will last. If you have the coin to spare get a new shortblock and at minimum just bolt on your original top end. That's the cheap rebuild.
Old Jan 21, 2008 | 12:00 AM
94 F-body's Avatar
I toasted my crank when I spun 6 rods, so you just have to start by pulling the motor and replacing the parts that got smoked. But there is a list of thing that will have to get replaced; fluids, gaskets, barrings, other than that play it by ear.
Old Jan 21, 2008 | 12:21 AM
93_SilveradoTPI's Avatar
If you thrown a rod you would know for sure that you did. Pull the oil pan off and look in.
The biggest thing is to make sure the block is good. But you want to take apart the block apart carefully and see what the story its telling you.
Old Jan 21, 2008 | 11:13 AM
1badzee's Avatar
ive never experienced a spun bearing or thrown rod.. what does it feel like? lol.. is it a bunch of noise and power loss?
